1100M
  • X-Axis: 18 in. (457 mm)
  • Y-Axis: 11 in. (279 mm)
  • Z-Axis: 16.25 in. (413 mm)
  • Spindle Power: 2 hp (1.49 kW)
  • Maximum Speed: 7500 RPM
  • Transmission: Poly-V Belt
  • Spindle Taper: R8
  • Thread Machining: Tension/Compression Auto Reversing Thread Mill
Maximum Feed Rate
  • X- and Y-Axis: 110 IPM (2.79 m/min)
  • Z-Axis: 90 IPM (2.29 m/min)
  • Primary Power Required: Single-Phase 230 Vac, 50/60Hz, 20A breaker
  • Table Size: 34 in. × 9.5 in. (863 mm x 241 mm)
  • Table Slots: 5/8 in. - Three slots (15.9 mm - Three slots)
  • Spindle Nose to Table Max. Clearance: 18 in. (457 mm)
  • Spindle Centerline to Machine Column: 11 in. (279 mm)
  • Typical System Footprint: 69 in. × 56.5 in. (1753 mm x 1435 mm)
  • Overall System Height: 96 in. (2438 mm)
  • Typical System Weight: 1600 lb (726 kg)
  • Maximum Weight on Table: 500 lbs. (227 kg)
Frame
  • Frame and Table: Cast iron frame and table, with hand-scraped hydrodynamic ways and tapered adjustment gibs
  • Way Surfaces: Low-friction PTFE-filled, Acetyl-bonded sliding surface. Similar to Rulon® and Turcite®.
  • 1 Year Warranty against defects in material and workmanship. Extended Warranty available.
Accessories
  • Automatic Tool Changer
  • Power Drawbar
  • 4th Axis
  • Smart Cool™ Coolant System
  • RapidTurn™ Chucker Lathe Accessory
  • Full Enclosure
  • High-Speed Spindle
Controller
Machine Dimentions
X-Axis: 18 in.(457 mm)
Z-Axis: 16.25 in. (412 mm)
Spindle Power: 2 hp (1.5 kW)
Transmission: Poly-V belt
Spindle Taper: R8
Maximum Feed Rate
Power Required: Single-Phase 208-240 Vac*, 50/60 Hz, 20 A Breaker
PATHPILOT® Controller
80GB program memory
Assembly
Technical Specifications
Machine Dimentions
Spindle Taper: R8
Maximum Feed Rate
80GB program memory
Assembly
