EXPLORE FREE CNC PROJECTS & MACHINING RESOURCES
Looking for free CNC machining files and project ideas? The Tormach Project Library is your go-to resource for creative and practical CNC projects. Whether you're a hobbyist, educator, or professional machinist, explore a diverse collection of projects designed to inspire and enhance your CNC skills. From custom cookie cutters to precision-engineered automotive parts, find downloadable files and step-by-step guides to bring your ideas to life. Start machining today with Tormach!
Make your own fidget spinner
CNC Fidget Spinner
Fidget spinners are the latest craze. Here’s how to make a simple one out of brass that looks fancy and feels great in your hand, created by Caleb Kraft, one of the Tormach Brand Ambassadors.
Read more.....
Download Files
Visit the Tormach forums
Tormach Forums
Explore the Tormach Forums to discover CNC projects crafted by fellow machinists. See what others have built, share your own creations, and connect with a community passionate about CNC craftsmanship.
Visit Now
DIY Jack Stand project to make
DIY Jack Stand
When you're leveling your machine there are a number of tools you need to get the job done. A jack stand is one of them because it helps make the lifting and leveling process much easier.
Read more.....
Download Files
make this automotive sensor relocation part
Making an Automotive MAF Sensor Relocation Part
This little part gives someone the ability to relocate the MAF (mass air flow) sensor in their Mitsubishi Evolution. Since the factory part is plastic and integrated into the air box of the car, it is impossible to add an aftermarket intake to the engine.
Read more.....
Download Files
TTS tool fixture project to make
TTS Tighten - Loosen Fixture
This project comes to us from our customer Last Bastion Labs. Be sure to check this great project out - made on a PCNC 440 CNC Mill.
Read more.....
Download Files
make your own Darth Vader cookie molds
Darth Vader Cookie Mold
In this project, we are going to make a mold for Darth Vader shaped cookies from a plastic cutting board. I used cutting board material because it's food safe.
Read more.....
Download Files
engraving holiday decore project
Engraving Holiday Decor
Machining has a lot to offer when it comes to making holiday decorations. After stumbling onto a glass block in the clearance section of a hobby store, we took to our mill to do some fancy holiday engraving.
Read more.....
Download Files
Arduino Case Project to make
Arduino Enclosure
In this project, we’re going to create an aluminum enclosure for an Arduino. This project will walk you through a setup with multiple operations and the flipping of a part.
Read more.....
Download Files
FIRST Sprocket project to make
FIRST Robotics Sproket
FIRST provides opportunities for middle school and high school students to work together and build robots – what could be cooler!
Read more.....
Download Files
Pinewood Derby project to make
Precision Milled Pinewood Derby Car
Every year, Boy Scouts organizations host a Pinewood Derby - where the Scouts get to race against one another using cars they construct out of a block of pine.
Read more.....
Download Files
Euchre score block project to make
Make a Euchre Score Block
Read more.....
Download Files
Make your own mini mag light attachment
Making a 90 Degree Attachment for a Mini Maglite
Read more.....
Download Files
Make this unicorn cookie cutter project
Unicorn Cookie Cutter
This project comes to us from our customer Last Bastion Labs. Be sure to check this great project out - what a fun one to make with the kids.
Read more.....
Download Files
Yo-Yo project to make
Aluminum Yo-Yo
This project will walk you through CNC machining the parts needed to build a modern “butterfly” yo-yo on your Tormach 15L Slant-PRO CNC lathe.
Read more.....
Download Files
Easter egg project to make
2 Piece Easter Egg
This project will walk you through CNC machining a 2 piece threaded Easter egg on the Tormach 15L Slant Pro CNC lathe.
Read more.....
Download Files
Project Library
Project Library Banner Background
Mill Projects
Read more.....
Read more.....
Read more.....
DIY Jack Stand
Read more.....
CNC Fidget Spinner
Read more.....
Read more.....
Read more.....
Arduino Enclosure
Read more.....
Read more.....
Read more.....
Read more.....
Read more.....
Lathe Projects
2 Piece Easter Egg
Read more.....
Aluminum Yo-Yo
This project will walk you through CNC machining the parts needed to build a modern “butterfly” yo-yo on your Tormach Slant Pro CNC lathe.
Read more.....
Router Projects
Check out these great free projects for the 24R CNC Router available from our friends at Vectric. Visit the Vectric website to download the files, and start a free trial of Vectric software.
Visit the Vectric Project Library
