1100MX
- X-Axis: 18 in. (457 mm)
- Y-Axis: 11 in. (279 mm)
- Z-Axis: 16.25 in. (413 mm)
- Spindle Power: 2 hp (1.49 kW)
- Maximum Speed: 10,000 RPM
- Transmission: Poly-V Belt
- Spindle Taper: BT30
- Rigid Tapping, Tension/Compression, Thread Mill
Maximum Feed Rate
- X- and Y-Axis: 300 IPM (7.62 m/min)
- Z-Axis: 230 IPM (5.84 m/min)
- Primary Power Required: Single-Phase 230 Vac, 50/60Hz, 20A breaker
- Table Size: 34 in. × 9.5 in. (863 mm x 241 mm)
- Table Slots: 5/8 in. - Three slots (15.9 mm - Three slots)
- Spindle Nose to Table Max. Clearance: 17.25 in. (438 mm)
- Spindle Centerline to Machine Column: 11in. (279 mm)
- Typical System Footprint: 69 in. × 56.5 in. (1753 mm x 1435 mm)
- Overall System Height: 96 in. (2438 mm)
- Typical System Weight: 1600 lb (726 kg)
- Maximum Weight on Table: 500 lbs. (227 kg)
Frame
- Frame and Table: Cast iron frame and table, with hand-scraped hydrodynamic ways and tapered adjustment gibs
- Way Surfaces: Low-friction PTFE-filled, Acetyl-bonded sliding surface. Similar to Rulon® and Turcite®.
- 1 Year Warranty against defects in material and workmanship. Extended Warranty available
Accessories
- Automatic Tool Changer
- Power Drawbar
- 4th Axis
- Smart Cool™ Coolant System
- RapidTurn™ Chucker Lathe Accessory
- Full Enclosure
- High-Speed Spindle
Controller
User-Friendly Design
User-Definable Macros
Trajectory Planner/High-Speed Machining
Support For Up To 4-Axis Continuous Machining
Visual & Intuitive Conversational Programming
Expanded Memory: 80GB of system program memory
Second Home Position (Operator Defined)
Built-in Dropbox™ Support for Seamlessly Transferring Programs
WiFi Ready
USB I/O Kits Availble to Support up to 4 USB I/O (16 In/16 Out): Trigger aftermarket accessories such as auxiliary pumps, robotic part loaders, probes, and more.
