1500MX CNC MILL TECHNICAL SPECIFICATIONS
Travels:
X-Axis: 19.7 in. (500 mm)
Y-Axis: 13.8 in. (350 mm)
Z-Axis: 14 in. (356 mm)
Spindle Nose to Table: 3.7-17.7 in. (96-450 mm)
Continuous Power: 4 hp (3 kW)
Peak Power: 6hp (4.5 kW)
Spindle Speed: 250-10,000 RPM
Spindle Taper: BT30
Thread Machining: Rigid Tapping
Maximum Feed Rates
X- and Y-Axis: 1,200 IPM (30.5 m/min)
Z-Axis: 600 IPM (15.2 m/min)
Power and Air
Power Required: Single-Phase 230 Vac, 50/60 Hz, 30A breaker
Plug Type: NEMA L6-30P
Air Required: 90-120 psi
Table Size: 35 in. × 12.75 in. (0.9 m × 0.3 m)
Typical System Footprint: 86 in. × 104 in. × 94 in.(2.2 m × 2.6 m × 2.4 m)
Typical System weight: 2800 lbs. (1270 kg)
Maximum Weight on Table: 300 lbs. (136 kg)
Performance
Testing: Ballbar testing on every machine
Key Components
Frame: Bonded epoxy granite base and column castings
Ways: Linear rails
Motion System: EtherCAT control system
Shipping
Pallet Weight: Factory Assembled: 3210 lbs. (1456 kg) / Self Assembled: 2650 lbs. (1202 kg)
Crate Dimensions: Factory Assembled: 68 in. × 74 in. × 89 in. (1.7 m × 1.9 m × 2.3 m) / Self Assembled: 54 in. × 58 in. × 89 in.(1.4 m × 1.5 m × 2.3 m)
Please Note: The customer must have a forklift or loading dock to unload the crate.
Optional Accessories
16-pocket automatic tool changer (ATC)
microARC 6 – 6 in. (150 mm) 4th axis rotary table
36-gallon flood coolant tank and manual sprayer
Automatic enclosure washdown system
Wireless probe and tool setter
MQL system
Through-spindle coolant
Mist collector
Chip conveyor system (under development)
1-year warranty against defects in material and workmanship. Extended warranty available.
