770M
- X-Axis: 14" (356 mm)
- Y-Axis: 7.5" (191 mm)
- Z-Axis: 13.25" (337 mm)
- Spindle Power: 1.5 hp (1.12 Kw)
- Maximum Speed: 10,000 RPM
- Transmission: Poly-V Belt
- Spindle Taper: R8
- Thread Machining: Tension/Compression Auto Reversing Thread Mill
Maximum Feed Rate
- X- and Y-Axis: 135 IPM (3.43 m/min)
- Z-Axis: 110 IPM (2.79 m/min)
- Primary Power Required: Single-Phase 115 Vac, 50/60 Hz, 15A breaker
- Table Size: 26" × 8" (660 mm x 203 mm)
- Table Slots: 5/8" - Three slots (15.9 mm - Three slots)
- Spindle Nose to Table Max. Clearance: 14.25" (362 mm)
- Spindle Centerline to Machine Column: 8.6" (218 mm)
- Typical System Footprint: 56" × 48.5" (1422 mm x 1232 mm)
- Overall System Height: 88" (2235 mm)
- Typical System Weight: 950 lb (431 kg)
- Maximum Weight on Table: 500 lbs. (227 kg)
Frame
- Frame and Table: Cast iron frame and table, with hand-scraped hydrodynamic ways and tapered adjustment gibs
- Way Surfaces: Low-friction PTFE-filled, Acetyl-bonded sliding surface. Similar to Rulon® and Turcite®.
- 1 Year Warranty against defects in material and workmanship. Extended Warranty available.
Accessories
- Automatic Tool Changer
- Power Drawbar
- 4th Axis
- Smart Cool™ Coolant System
- RapidTurn™ Chucker Lathe Accessory
- Full Enclosure
- High-Speed Spindle
Controller
