770MX
  • X-Axis: 14 in. (356 mm)
  • Y-Axis: 7.5 in. (191 mm)
  • Z-Axis: 13.25 in. (337 mm)
  • Spindle Power: 1.5 hp (1.12 Kw)
  • Maximum Speed: 10,000 RPM
  • Transmission: Poly-V Belt
  • Spindle Taper: R8
  • Rigid Tapping, Tension/Compression, Thread Mill
Maximum Feed Rate
  • X- and Y-Axis: 300 IPM (7.62 m/min)
  • Z-Axis: 250 IPM (6.35 m/min)
  • Primary Power Required: Single-Phase 115 Vac, 50/60 Hz, 15A breaker
  • Table Size: 26 in. × 8 in. (660 mm x 203 mm)
  • Table Slots: 5/8 in. - Three slots (15.9 mm - Three slots)
  • Spindle Nose to Table Max. Clearance: 13.75 in. (349 mm)
  • Spindle Centerline to Machine Column: 8.6 in. (218 mm)
  • Typical System Footprint: 56 in. × 48.5 in. (1422 mm x 1232 mm)
  • Overall System Height: 88 in. (2235 mm)
  • Typical System Weight: 950 lb (431 kg)
  • Maximum Weight on Table: 500 lbs. (227 kg)
Frame
  • Frame and Table: Cast iron frame and table, with hand-scraped hydrodynamic ways and tapered adjustment gibs
  • Way Surfaces: Low-friction PTFE-filled, Acetyl-bonded sliding surface. Similar to Rulon® and Turcite®.
  • 1 Year Warranty against defects in material and workmanship. Extended Warranty available.
Controller
User-Friendly Design
User-Definable Macros
Trajectory Planner/High-Speed Machining
Support For Up To 4-Axis Continuous Machining
Visual & Intuitive Conversational Programming
Expanded Memory: 80GB of system program memory
Second Home Position (Operator Defined)
Built-in Dropbox™ Support for Seamlessly Transferring Programs
WiFi Ready
USB I/O Kits Availble to Support up to 4 USB I/O (16 In/16 Out): Trigger aftermarket accessories such as auxiliary pumps, robotic part loaders, probes, and more.
770MX ML Technical Specifications
Spindle Power: 2 hp / 1.49 kW
Peak Spindle Power: 4.5 hp / 3.35 kW
Spindle Taper: BT30
Tapping & Threading: Rigid Tapping, Tension/Compression, Thread Mill
Maximum Feed Rate
X- and Y-Axis: 450 IPM (11.4 m/min)
Z-Axis: 420 IPM (10.6 m/min)
Power and Air
Power Required: Single-Phase, 230 VAC*, 20A breaker
Air Required: 90-120 psi
Frame
Typical System Weight (Factory Assembled): 1500 lbs (681 kg)
EtherCAT Motion System: Absolute Encoder, EtherCAT Servos
Accessories
PathPilot® Touchscreen Operator Console (Standard)
Air Gun Kit
Mist Collector Kit (Must be Wall or Floor Mounted)
WallControl Compatible Tool / Storage Racks
Warrranty
