PCNC 440
  • X-Axis: 10" (254 mm)
  • Y-Axis: 6.25" (158.75 mm)
  • Z-Axis: 10" (254 mm)
  • Spindle Power: 0.75 hp (0.56 kW)
  • Maximum Speed: 10,000 RPM
  • Transmission: Poly-V Belt
  • Spindle Taper: R8
  • Thread Machining: Thread Mill
Iron
  • Frame and Table: Cast iron frame and table, with hand scraped hydrodynamic ways and tapered adjustment gibs
  • Way Surfaces: Low friction PTFE-filled acetyl bonded sliding surface. Similar to Rulon® and Turcite®
Maximum Feed Rate
  • X- and Y-Axis: 135 IPM (3.43 m/min)
  • Z-Axis: 110 IPM (2.79 m/min)
  • Power Required: Single-Phase, 115 Vac 50/60 Hz, 15A Breaker
  • Table Size: 18" × 6.30" (457 mm x 160 mm)
  • Table Slots: 3/8" - Three slots (9.5 mm - Three slots)
  • Spindle Nose to Table Max. Clearance: 12" (305 mm)
  • Spindle Centerline to Machine Column: 6.5" (165 mm)
  • Typical System Footprint: 42" × 36" (1067 mm x 914 mm)
  • Overall System Height: 72" (1829 mm)
  • Typical System Weight: 600 lb (272 kg)
  • Maximum Weight on Table: 150 lb (68 kg)
  • Warranty: 1 Year Warranty against defects in material and workmanship. Extended Warranty available.
Frame
  • Frame and Table: Cast iron frame and table, with hand-scraped hydrodynamic ways and tapered adjustment gibs
  • Way Surfaces: Low-friction PTFE-filled, Acetyl-bonded sliding surface. Similar to Rulon® and Turcite®.
Accessories
  • Automatic Tool Changer
  • Power Drawbar
  • 4th Axis (COMING SOON!)
  • Smart Cool™ Coolant System
  • Full Enclosure
  • Flood Coolant
Controller
View the Mill Comparison Table
X-Axis: 10 in. (254 mm)
Y-Axis: 6.25 in. (158.75 mm)
Z-Axis: 10 in. (254 mm)
Maximum Speed: 10.000 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Tapping: Thread Mill
Maximum Feed Rate
PATHPILOT® Controller
Assembly
Spindle Taper: R8
Maximum Feed Rate
80GB program memory
Assembly
