TTS Tighten - Loosen Fixture
Make your own TTS Tighten-Loosen fixure with a Tormach millMake your own TTS Tighten-Loosen fixure with a Tormach mill
The TTS Tighten/Loosen Fixture is a simple but essential tool for anyone using Tormach's Tooling System (TTS). It securely holds TTS tool holders in place while you tighten or loosen collets, end mills, or other cutting tools—making tool changes faster, easier, and safer. Whether you're assembling a tool before a job or swapping out cutters mid-project, this fixture helps eliminate the hassle of slippage or misalignment.
Perfect for both beginner and seasoned machinists, the TTS Tighten/Loosen Fixture is a must-have for any organized CNC workspace. Pair it with your Tormach mill and tool cart for maximum efficiency and convenience.
This project is made by our friends at Last Basion Labs from aluminum on a PCNC 440 Mill.
Be sure to check out their YouTube Channel for other great content - Visit Last Bastion Labs on YouTube
This project is made by our friends at Last Basion Labs from aluminum on a PCNC 440 Mill. Download the files to make this TTS Tighten - Loosen Fixture.
