1 Position Gang Block
$119.00
The 1 Position Gang Block is a 1 position gang block that holds downs with end stop; Left hand bore
1 Position Gang Block. Use as a Spot-Drill-Tap Station.
  • Center Height: 1/2 in.
  • Bore: 0.750 in.
  • Overall Length: 1.5 in.
  • Bore Location: Left
  • Integrated End Stop for quick changeover repeatability
  • 1 Hold down
  • 2 Set Screws per position
  • Black Oxide Finish
