1100M Basic EDU Bundle
1100M Mill This product is required for the machine. $14,035.00
1100M Printed Manual $25.95
1100M / 1100MX Stand This product is required for the machine. $2,885.00
1100M Chip Tray This product is required for the machine. $639.00
1100M Enclosure Kit This product is required for the machine. $3,949.00
Door Lock Switch Kit This product is required for the machine. $379.00
Manual Oil Pump This product is required for the machine. $115.00
Lifting Bar Kit $249.00
PathPilot Controller This product is required for the machine. $1,055.00
PathPilot Controller Vesa Mount This product is required for the machine. $25.95
Standard LCD Monitor This product is required for the machine. $365.00
Drawbar Wrench/Hammer $65.00
Machine Dimentions
X-Axis: 18 in.(457 mm)
Y-Axis: 11 in. (279 mm)
Z-Axis: 16.25 in. (412 mm)
Spindle Power: 2 hp (1.5 kW)
Maximum Speed: 7500 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Maximum Feed Rate
Z-Axis: 90 IPM (2.29 m/min)
Power Required: Single-Phase 208-240 Vac*, 50/60 Hz, 20 A Breaker
PATHPILOT® Controller
80GB program memory
Assembly
Technical Specifications
Machine Dimentions
Spindle Taper: R8
Maximum Feed Rate
80GB program memory
Assembly
