1100M Premium Package
1100M Mill This product is required for the machine. $14,035.00
1100M / 1100MX Stand $2,885.00
1100M Chip Tray $639.00
1100M Backsplash Kit $299.95
1100M Enclosure Kit $3,949.00
Recommended items:
Related items:
How to choose your oiler
How to choose your oiler?
Oilers
Manual Oil Pump $115.00
Additional Options:
Additional Options:
Lifting Bar Kit $249.00
Door Lock Switch Kit $379.00
1100M Printed Manual $25.95
How to choose system control
1100M/M+/MX PathPilot Operator Console $2,529.00
$31.95
Waterproof Mouse $31.95
$55.00
Additional Options:
$31.95
$55.00
Touch Screen Kit $589.00
Standard LCD Monitor $365.00
Controller Arm $465.00
Additional Options:
TTS™ Gauge Holder: 10 mm
Related items:
Active Probe Kit $2,169.00
TTS™ Gauge Holder: 12 mm
Related items:
Coolant
Additional Options:
12-Pocket Automatic Tool Changer for the 1100M $6,475.00
microARC 4 Subplate $145.00
Recommended items:
RapidTurn Starter Package
remove
$3,729.00
Additional Options:
RapidTurn Deluxe Package
remove
$4,809.00
Additional Options:
Workholding Setup Guide
Work Stop $65.00
Multi-V 5 in. Jaw Set $155.00
Additional Options:
4 in. CNC Vise $475.00
4 in. Parallel Set $65.00
Work Stop $65.00
Additional Options:
Work Stop $65.00
Additional Options:
Additional Options:
90° Spot Drill Kit
More Info In Stock
1/8 in. -90° Drills $9.95
1/4 in. -90° Drills $11.95
3/8 in. -90° Drills $15.95
1/2 in. -90° Drills $24.95
Manual Operator Set (Metric) $325.00
TTS™ Saw Arbor: 1 in. $95.00
TTS™ Machinable Blank $38.95
Huot ER16 Collet Rack $95.00
Huot ER20 Collet Rack $95.00
TTS™ SuperFly Cutter Kit
Related items:
TTS™ Mini-Shear .750 in.
Related items:
Mini-Shear - .500 in.
Related items:
Related items:
Related items:
Shear-Hog - 2 in.
ADEH 431 (0.010 $255.00
Related items:
TTS™ Shear-Hog - 0.750 in.
Related items:
Related items:
Related items:
Spindle Speeder $1,895.00
High Speed Spindle Kit for Tormach 1100 $2,229.00
QC Motor Connection Kit QC Motor Connection Kit
Stop-Loc Setup Tool $22.95
1-2-3 Block Set $42.95
Machine Dimentions
X-Axis: 18 in.(457 mm)
Y-Axis: 11 in. (279 mm)
Z-Axis: 16.25 in. (412 mm)
Spindle Power: 2 hp (1.5 kW)
Maximum Speed: 7500 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Maximum Feed Rate
Z-Axis: 90 IPM (2.29 m/min)
Power Required: Single-Phase 208-240 Vac*, 50/60 Hz, 20 A Breaker
PATHPILOT® Controller
80GB program memory
Assembly
Technical Specifications
Machine Dimentions
Spindle Taper: R8
Maximum Feed Rate
80GB program memory
Assembly
