1100M Intermediate EDU Bundle
1100M Mill This product is required for the machine. $14,035.00
1100M Printed Manual $25.95
1100M / 1100MX Stand This product is required for the machine. $2,885.00
1100M Chip Tray This product is required for the machine. $639.00
1100M Enclosure Kit This product is required for the machine. $3,949.00
Door Lock Switch Kit This product is required for the machine. $379.00
Automatic Oiler Kit (230V) for 1100M / 1100MX / 770MX* This product is required for the machine. $819.00
Lifting Bar Kit $249.00
1100M/M+/MX PathPilot Operator Console This product is required for the machine. $2,529.00
Power Drawbar Kit for 1100M / 770M This product is required for the machine. $1,515.00
Flood Coolant Kit (1/8 HP) for 1100M/MX and 770M/MX This product is required for the machine. $639.00
Haimer 3D Sensor - New Generation (Metric) $549.00
TTS™ Gauge Holder: 12 mm $42.95
Machine Dimentions
X-Axis: 18 in.(457 mm)
Y-Axis: 11 in. (279 mm)
Z-Axis: 16.25 in. (412 mm)
Spindle Power: 2 hp (1.5 kW)
Maximum Speed: 7500 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Maximum Feed Rate
Z-Axis: 90 IPM (2.29 m/min)
Power Required: Single-Phase 208-240 Vac*, 50/60 Hz, 20 A Breaker
PATHPILOT® Controller
80GB program memory
Assembly
Technical Specifications
Machine Dimentions
Spindle Taper: R8
Maximum Feed Rate
80GB program memory
Assembly
