The all in one machine console allows you to operate your M, M+ or MX machine with built in hardware knobs for feed and speed overrides and a durable hand-held jog pendant for precise manual positioning of the machine.
Keep complete control of your CNC program operation with hardware override knobs for feedrate and spindle RPM. Quickly adjust program speed even when wearing gloves and without fumbling with a mouse. Start and pause your program with large front-panel buttons for Cycle Start and Feedhold.
Features:
- PathPilot Installed
- Wireless-N Wi-Fi Adapter
- Jog Pendant (X, Y, Z, and A axes, with three jog size increments from 0.0001” to 0.01”)
- Cycle Start and Feedhold Buttons along with 0% - 200% override knobs for Feed Rate, RPM, and Maximum Velocity
- Touchscreen Controls
- RGB Machine Status Light behind Tormach logo on front panel
- Hardware E-Stop and Machine Reset buttons
Some assembly required.
- 1100MX
- 1100M+
- 1100M
Requirements
- Tormach machine with Ethernet control (M, M+, or MX mill)
- Machine Enclosure
- Waterproof Mini Keyboard
- Waterproof Mouse
Specifications
Storage Capacity |
40GB / 21GB |
RAM |
4GB |
Voltage (Input) |
115 VAC or 230 VAC |
Screen Size (Diagonal) |
17 in. (43 cm) |
What’s In the Box?
- Machine Controller
- Jog Pendant
- Wi-Fi Adapter
- Power Adapter
- Controller Enclosure Mount
- Controller Wire Kit
