1100M / 1100MX Stand
$2,885.00
450 lbs.
The 1100M / 1100MX Stand is a heavy-duty, welded-steel stand for the 1100M / 1100MX CNC mill that includes a rolling coolant tank and integrated chip drawer.
Note: This item has a flat rate shipping charge inside the contiguous United States. This includes shipping to a US port of the customer's choice for freight forwarding. Destinations outside of the US will incur additional freight charges.
This heavy-duty, welded steel stand provides a rigid foundation for your 1100M and 1100MX and space to safely store the PathPilot controller. Its centrally-located, rolling chip basket and coolant tank save you time between chip cleanouts and coolant top-offs (when machine is not in operation). The chip basket holds up to 50 lb (20 kg) of chips and features a fine mesh screen at the bottom of the drawer to help keep chips out of the coolant. The coolant tank holds up to 12 gal (45 L) of coolant and the system recycles/reclaims it for more efficient usage.
In addition, you can easily:
  • Track coolant use with the coolant tank’s fill level gauge
  • Refill the coolant tank by sliding it out from the front of the stand
  • Easily level the machine with the stand’s threaded, adjustable feet
  • Move the stand using common pallet jacks
Some assembly required.
  • 1100M or 1100MX
  • PCNC 1100 (Series 1 through 3) without an enclosure
  • Flood Coolant Kit (1/8 hp) (optional; not included)
What's In the Box?
NOTE: Coolant pump and hoses not included
The stand includes:
  • Removable chip drawer/Coolant tank combo
  • Leveling feet
