1100MX Advanced EDU Bundle
1100MX Mill This product is required for the machine. $29,479.00
1100MX Enclosure Kit
1100MX Enclosure Kit This product is required for the machine. 1100MX Enclosure Kit
1100MX Chip Tray
1100MX Chip Tray This product is required for the machine. 1100MX Chip Tray
1100M / 1100MX Stand
1100M / 1100MX Stand This product is required for the machine. 1100M / 1100MX Stand
1100M/M+/MX PathPilot Operator Console This product is required for the machine. 1100M/M+/MX PathPilot Operator Console
Door Lock Switch Kit This product is required for the machine. $379.00
Automatic Oiler Kit (230V) for 1100M / 1100MX / 770MX* This product is required for the machine. $819.00
Lifting Bar Kit $249.00
1100MX Printed Manual $25.95
Flood Coolant Kit (1/8 HP) for 1100M/MX and 770M/MX This product is required for the machine. $639.00
Oil Skimmer Kit for 1100M/1100MX, 770M/770MX, and PCNC 440 This product is required for the machine. $365.00
12-Pocket Automatic Tool Changer for the 1100MX (BT30) This product is required for the machine. $6,745.00
Passive Probe, 5 pin DIN connector $649.00
BT30 Tool Holder, Probe, 10 mm $65.00
Huot ER20 Collet Rack $95.00
1100MX TECHNICAL SPECIFICATIONS
X-Axis: 18 in. (457 mm)
Y-Axis: 11 in. (279 mm)
Z-Axis: 16.25 in. (413 mm)
Spindle Power: 2 hp / 1.49 kW
Maximum Speed: 10,000 RPM
Transmission: Poly-V belt
Spindle Taper: BT30
Maximum Feed Rate
Z-Axis: 230 IPM (5.84 m/min)
Power Required: Single-Phase 230 Vac*, 50/60Hz, 20A breaker
Frame
Table Size: 34 in. × 9.5 in. (863 mm x 241 mm)
Spindle Nose to Table Max Clearance: 17.25 in. (438 mm)
Spindle Centerline to Machine Column: 11 in. (279 mm)
Typical System Weight (includes ATC): 1850 lb (840 kg)
1-Year Warranty against defects in material and workmanship. Extended Warranty available.
Assembly
As the default, Tormach equipment is shipped in crates and owners assemble and commission machines. But we recognize the demand for turn-key machines so that's why we offer machine assembly as an add-on service. A Tormach professional installs, aligns, and tests major componenets, allowing you to quickly commission you machine once it arrives.
Spindle Taper: BT30
Maximum Feed Rate
Power Required: Single-Phase 230 Vac, 50/60Hz, 20A breaker
Frame
PATHPILOT® Controller
80GB program memory
Assembly
