1100MX CNC Mill Configurator
1100MX Mill This product is required for the machine. $29,479.00
1100MX Enclosure Kit
1100MX Enclosure Kit This product is required for the machine. 1100MX Enclosure Kit
1100MX Chip Tray
1100MX Chip Tray This product is required for the machine. 1100MX Chip Tray
1100M / 1100MX Stand
1100M / 1100MX Stand This product is required for the machine. 1100M / 1100MX Stand
1100M/M+/MX PathPilot Operator Console This product is required for the machine. 1100M/M+/MX PathPilot Operator Console
Related items:
How to choose your oiler
How to choose your oiler?
Oilers
Manual Oil Pump $115.00
Additional Options:
Additional Options:
Lifting Bar Kit $249.00
Door Lock Switch Kit $379.00
1100MX Printed Manual $25.95
Waterproof Mouse $31.95
Pull Stud, BT30 45-Degree
Related items:
BT30 Tool Holder, Probe, 12mm
Related items:
Coolant
Additional Options:
How to choose your toolchanging option
Tool Changing on Tormach Machines
An Automatic Tool Changer (ATC) can boost your workflow by cutting manual steps, saving time, and reducing errors. This video shows how PathPilot handles tool changes and management, whether you’re running your Tormach machine with or without an ATC.
12-Pocket Automatic Tool Changer for the 1100MX (BT30) $6,745.00
microARC 4 Subplate $145.00
Recommended items:
RapidTurn Starter Package
remove
$3,729.00
Additional Options:
RapidTurn Deluxe Package
remove
$4,809.00
Additional Options:
Workholding Setup Guide
Work Stop $65.00
Multi-V 5 in. Jaw Set $155.00
Additional Options:
4 in. CNC Vise $475.00
4 in. Parallel Set $65.00
Work Stop $65.00
Additional Options:
Work Stop $65.00
Additional Options:
Additional Options:
90° Spot Drill Kit
More Info In Stock
1/8 in. -90° Drills $9.95
1/4 in. -90° Drills $11.95
3/8 in. -90° Drills $15.95
1/2 in. -90° Drills $24.95
Starter BT30 Toolholding Set
ER20 Toolholder 5 Pack
ER16 Toolholder 5 Pack
ER32 Collet Set (6 Pcs.) - Inch $119.00
Huot ER16 Collet Rack $95.00
Huot ER20 Collet Rack $95.00
BT30 Operator's Kit (Metric) $1,575.00
BT30 Tool Holder, End Mill 1/8 in, 50mm
Additional Options:
BT30 Tool Holder, End Mill 1/4 in, 50mm
Additional Options:
BT30 Tool Holder, End Mill 3/8 in, 50mm
Additional Options:
BT30 Tool Holder, End Mill 1/2 in, 50mm
Additional Options:
BT30 Tool Holder, Drill Chuck 8mm, 80mm
Additional Options:
BT30 Tool Holder, ER16, 60mm Gage Length
Additional Options:
BT30 Tool Holder, ER16M (Mini-Nut), 60mm Gage Length
Additional Options:
BT30 Tool Holder, ER20, 60mm Gage Length
Additional Options:
BT30 Tool Holder, ER20M (Mini-Nut), 60mm Gage Length
Additional Options:
BT30 Tool Holder, ER32, 60mm Gage Length
Additional Options:
Face Mill 38mm Kit
Face Mill - 38 mm $245.00
$95.00
$9.95
Related items:
Shear-Hog - 2 in. Tooling Bundle
More Info In Stock
Shear-Hog - 2 in. $485.00
$95.00
$9.95
ADEH 431 (0.010 $255.00
Related items:
Shearhog 1 in. Tooling Bundle
More Info In Stock
Shear-Hog - 1 in. MIT Cutting Head $279.00
BT30 Tool Holder, Modular, M12, 50mm $95.00
Related items:
DIJET QM Mini Modular Insert High Feed End Mill: 1/2 in. Tooling Bundle
More Info In Stock
DIJET QM Mini Modular Insert High Feed End Mill: 1/2 in. $335.00
BT30 Tool Holder, Modular, M6, 50mm $95.00
Related items:
Stop-Loc Setup Tool $22.95
1-2-3 Block Set $42.95
1100MX TECHNICAL SPECIFICATIONS
X-Axis: 18 in. (457 mm)
Y-Axis: 11 in. (279 mm)
Z-Axis: 16.25 in. (413 mm)
Spindle Power: 2 hp / 1.49 kW
Maximum Speed: 10,000 RPM
Transmission: Poly-V belt
Spindle Taper: BT30
Maximum Feed Rate
Z-Axis: 230 IPM (5.84 m/min)
Power Required: Single-Phase 230 Vac*, 50/60Hz, 20A breaker
Frame
Table Size: 34 in. × 9.5 in. (863 mm x 241 mm)
Spindle Nose to Table Max Clearance: 17.25 in. (438 mm)
Spindle Centerline to Machine Column: 11 in. (279 mm)
Typical System Weight (includes ATC): 1850 lb (840 kg)
1-Year Warranty against defects in material and workmanship. Extended Warranty available.
Assembly
As the default, Tormach equipment is shipped in crates and owners assemble and commission machines. But we recognize the demand for turn-key machines so that's why we offer machine assembly as an add-on service. A Tormach professional installs, aligns, and tests major componenets, allowing you to quickly commission you machine once it arrives.
Spindle Taper: BT30
Maximum Feed Rate
Power Required: Single-Phase 230 Vac, 50/60Hz, 20A breaker
Frame
PATHPILOT® Controller
80GB program memory
Assembly
