120V-240V Transformer Kit
$945.00
63 lbs.
Only 1 left
120 V to 240 V Power Transformer (15 A Input)
This unit allows a 240 V machine to be operated from a standard 120 V, 15 A outlet. It uses an isolation transformer to step up the voltage and provide a grounded 240 V output suitable for equipment that normally requires 220-240VAC.
Key Specifications
  • Input: 120 VAC, 15 A max (standard wall outlet)
  • Output: 240 VAC (L1–L2), single-phase
  • Maximum output power: ~1.8 kVA (limited by input circuit)
  • Typical output current: up to ~7–8 A at 240 V
Features
  • Provides 240 V power from a 120 V source
  • Grounded output (each leg ~120 V to ground)
  • Built-in 15 A circuit breaker on the input
  • NEMA 5-15P input plug and NEMA 6-20R output receptacle
  • Heavy-duty isolation transformer for stable operation
Intended Use
  • For machines that require 240 V line-to-line power only
  • Suitable for applications where only a 120 V, 15 A circuit is available
  • Ideal for reduced-power operation of larger equipment
Limitations
  • Output power is limited by the input circuit; not suitable for full-load 20 A operation at 240 V
  • Does not provide a neutral conductor (240 V loads only)
This is a straightforward, plug-and-use solution for running compatible 240 V equipment where only standard 120 V power is available.
