1500MX Equipped Package
1500MX Base Mill $35,450.00
<p>Includes 1500MX CNC mill, PathPilot operator console, and mill enclosure. This option is self-assembled by the customer.</p>
$6,475.00
16-Pocket Automatic Tool Changer for the 1500MX $6,475.00
$3,125.00
1500MX Flood Coolant Kit $3,125.00
Additional Options:
1500MX Assembled with ATC and Flood Coolant System $46,450.00
<p>Includes everything in the base machine (mill, operator console, and enclosure) plus an automatic tool changer, flood coolant system and factory assembly. Assembly includes the base mill, enclosure, ATC, console and coolant plumbing. <p><b><span style="color:red;">Please note:</span> </b> customer must have a forklift or loading dock for unloading the crate and is responsible for unpacking, leveling and commissioning the machine after delivery.</p>
16-Pocket Automatic Tool Changer: 1500MX
More Info In Stock
Related items:
Wireless Probe and Tool Setter Kit $6,645.00
Passive Probe, M12 connector $723.95
Pull Stud, BT30 45-Degree
Wired Probe / ETS Adapter Cable $99.00
Required for connection a Passive Probe and/or Electronic Tool Setter. Only 1 cable required per machine.
Recommended items:
Electronic Toolsetter, 24v, M12 Connector $1,685.00
Recommended items:
BT30 Tool Holder, Probe, 12mm
Related items:
Adding a microARC 6 fourth axis to your Tormach Mill
The microARC6 4th Axis
Looking to take your Tormach 1500MX to the next level? Add our 4th axis and you'll be able to create more complex parts as it allows to cut along the arc of your workpiece. The 4th axis also makes it possible to access more sides and angles without having to manually move the piece into a separate fixture.
microARC6
microARC 6 - 150mm Rotary Table Kit for 1500MX $7,950.00
microARC 6 Subplate $295.00
Adjustable Tailstock (Medium) $195.00
Additional Options:
Coolant Options for the 1500MX CNC Mill
Coolant System Options
The Tormach 1500MX CNC Mill has multiple options when it comes to coolant. The flood coolant system is efficient at chip removal, lubrication, and heat management. Optional washdown bars keep chips from building up in the enclosure. Also available is a minimum quantity lubrication (MQL) system.
Coolant Options
Through Spindle Coolant Kit, 1500MX $7,950.00
Automatic Chip Tray Washdown Bar Kit $2,544.00
Requires 1500MX Flood Coolant Kit (PN 51567) when purchased with the self-assembled base machine.
Coolant Filter Assembly for 1500MX
Mist Collector, 420cfm $2,315.00
Oil Skimmer Kit for 1500MX $355.00
1500MX Chip Conveyor Kit $6,475.00
1500MX Machine Way Oil (Citgo EP Compound 220), 1 GAL $45.95
Waterproof Mouse $31.95
Tool Storage Rack Assembly, 1500MX $379.00
USB Camera for PathPilot-Controlled Machines $95.00
Workholding Setup Guide
6 in. CNC Vise - Precision Angle Lock $685.00
6 in. Parallel Set $95.95
Standard 6 in. Aluminum Soft Jaw Set $32.95
Mitee-Bite TalonGrip Steel Jaw Set For 6 in. Vises $225.00
Mitee-Bite VersaGrip Steel Jaw Set For 6 $224.95
Additional Options:
1-2-3 Block Set $42.95
SMW Fixture Tooling Plate for 1500MX (4140 Steel)
Includes fixture tooling plate (PN 51514) bundled with mounting hardware and the most popular fixturing accessories (PN 52220).
Additional Options:
SMW Fixture Tooling Plate for 1500MX (Aluminum, Black Anodized 7075)
Includes fixture tooling plate (PN 51798) bundled with mounting hardware and the most popular fixturing accessories (PN 52220).
Additional Options:
Stop-Loc Setup Tool $22.95
100MM (4 in.) Self-Centering Pneumatic CNC Vise $2,795.00
100mm (4 in.) Pneumatic Vise Subplate $189.00
100mm (4 in.) Pneumatic Vise Subplate - Dual $319.00
100mm (4 in.) Pneumatic CNC Vise Aluminum Soft Jaws $195.00
100mm (4 in.) Pneumatic CNC Vise Steel Soft Jaws $195.00
Additional Options:
90° Spot Drill Kit
More Info In Stock
1/8 in. -90° Drills $9.95
1/4 in. -90° Drills $11.95
3/8 in. -90° Drills $15.95
1/2 in. -90° Drills $24.95
Starter BT30 Toolholding Set
Deluxe BT30 Toolholding Set
ER20 Toolholder 5 Pack
ER16 Toolholder 5 Pack
Deluxe BT30 Toolholding Set (Metric)
ER16 TSC Sealed Collet Set (17 Pcs.) - Inch $355.00
ER16 TSC Sealed Collet Set (8 Pcs.) - Metric $169.00
ER20 TSC Sealed Collet Set (25 Pcs.) - Inch $509.00
ER20 TSC Sealed Collet Set (11 Pcs.) - Metric $219.00
Pull Stud, BT30-45 deg., Thru Spindle Coolant (TSC) $16.95
When using Through Spindle Coolant (TSC), one TSC Pull Stud is required for each BT-30 toolholder.
Face Mill 38mm Kit
Face Mill - 38 mm $245.00
Related items:
Face Mill 1 1/2 in. Kit
Face Mill - 1 1/2 in. $345.00
Related items:
1500MX CNC MILL TECHNICAL SPECIFICATIONS
X-Axis: 19.7 in. (500 mm)
Y-Axis: 13.8 in. (350 mm)
Z-Axis: 14 in. (356 mm)
Spindle Nose to Table: 3.7-17.7 in. (96-450 mm)
Continuous Power: 4 hp (3 kW)
Peak Power: 6hp (4.5 kW)
Spindle Speed: 250-10,000 RPM
Spindle Taper: BT30 (sealed bearing)
Thread Machining: Rigid Tapping
Maximum Feed Rates
X- and Y-Axis: 1,200 IPM (30.5 m/min)
Z-Axis: 600 IPM (15.2 m/min)
Power and Air
Power Required: Single-Phase 230 Vac*, 50/60 Hz, 30A breaker**
Plug Type: NEMA L6-30P
Air Required: 90-120 psi
*±10%, best performance at 240 vac, **Additonal outlets may be required for optional accessories
Table Size: 35 in. × 12.75 in. (0.9 m × 0.3 m)
Typical System Footprint: 86 in. × 104 in. × 94 in.(2.2 m × 2.6 m × 2.4 m)
Typical System weight: 2800 lbs. (1270 kg)
Maximum Weight on Table: 300 lbs. (136 kg)
Performance
Testing: Ballbar testing on every machine
Key Components
Frame: Bonded epoxy granite base and column castings
Ways: Linear rails
Motion System: EtherCAT control system
Shipping
Pallet Weight: Factory Assembled: 3210 lbs. (1456 kg) / Self Assembled: 2650 lbs. (1202 kg)
Crate Dimensions: Factory Assembled: 67 in.(D) × 73.25 in.(W) × 85 in.(H) (1.7 m × 1.86 m × 2.16 m) / Self Assembled: 61.5 in.(D) × 57 in.(W) × 86 in.(H)(1.56 m × 1.45 m × 2.18 m)
Optional Accessories
16-pocket automatic tool changer (ATC)
microARC 6 – 6 in. (150 mm) 4th axis rotary table
36-gallon flood coolant tank and manual sprayer
Automatic enclosure washdown system
Wireless probe and tool setter
MQL system
Through-spindle coolant
Mist collector
Chip conveyor system
1-year warranty against defects in material and workmanship. Extended warranty available.
Maximum Feed Rates
Power and Air
Performance
Key Components
Ways: Linear rails
Shipping
Crate Dimensions: Factory Assembled: 68 in. × 74 in. × 89 in. (1.7 m × 1.9 m × 2.3 m) / Self Assembled: 54 in. × 58 in. × 89 in.(1.4 m × 1.5 m × 2.3 m)
MQL system
Mist collector
Travels:
Spindle Taper: BT30
Maximum Feed Rates
Power and Air
Power Required: Single-Phase 230 Vac, 50/60 Hz, 30A breaker
Performance
Key Components
Ways: Linear rails
Shipping
Please Note: The customer must have a forklift or loading dock to unload the crate.
MQL system
Mist collector
Chip conveyor system (under development)
Tormach Troubleshooting
LOOKING FOR HELP WITH YOUR 1500MX?
Visit the Tormach Support Site to find Manuals, Technical Documents, Datasheets, Service Bulletins, The Knowledge Base and Troubleshooting Guides.
View Our Support Section
