15L Gang Tooling Package
15L Slant-PRO CNC Lathe This product is required for the machine. $20,995.00
<div style="color: red; font-weight: 600;">30% off while supplies last. Discount shown in cart.</div>
How to choose your oiler
How to choose your oiler?
Oilers
Automatic Oiler Kit (230V) for 15L / PCNC 1100 $819.00
Additional Options:
Manual Oil Pump $115.00
Additional Options:
15L Printed Manual $25.95
Lifting Kit for Tormach 15L Slant-PRO $429.00
Light Kit for Tormach 15L Slant-PRO $209.00
Related items:
Controller Arm $465.00
$55.00
$31.95
Waterproof Mouse $31.95
Touch Screen Kit $589.00
Standard LCD Monitor $365.00
Recommended items:
Floating Tramp Oil Collection Pillow $17.95
Gang Tool Coolant Accessory Kit, 15L/LX $119.00
Turret Kit for Tormach 15L Slant-PRO $5,395.00
4 Inch Length Coolant Nozzle for Turret 10-Pack $48.95
Boring Bar Holder for Turret $349.00
Boring Bar Holder for Turret (Unfinished Bore) $225.00
OD Turning/Facing Holder for Turret $325.00
Recommended items:
Automatic Collet Closer for 15L Slant-PRO $3,515.00
Recommended items:
Quick Change Tool Post Kit for 15L/LX Lathe $1,079.00
ER20M x 3/4 in. Collet Chuck $59.00
Recommended items:
ER16M x 3/4 $59.00
Recommended items:
ER11M x 3/4 in. Collet Chuck $44.95
ER11M Collet Nut Wrench $20.95
Recommended items:
Turret Tool Holder Bushing - 1/4 in. ID $69.95
Turret Tool Holder Bushing - 3/8 in. ID $51.95
Turret Tool Holder Bushing - 1/2 in. ID $51.95
Turret Tool Holder Bushing - 5/8 in. ID $46.95
Long Gang Plate $565.00
Short Gang Plate $449.00
3 Position Gang Block $185.00
Gang Block Bushing - 1/4 in. ID $51.95
Gang Block Bushing - 5/16 in. ID $51.95
Gang Block Bushing - 3/8 in. ID $51.95
Gang Block Bushing - 1/2 in. ID $51.95
Gang Block Bushing - 5/8 in. ID $51.95
Recommended items:
1 Position Gang Block $119.00
Recommended items:
RH Heavy Duty Gang Block $195.00
Shim Kit for Heavy Duty Gang Blocks $79.00
Recommended items:
LH Heavy Duty Gang Block $195.00
Recommended items:
Riser for 1/2 in. Center Gang Blocks $215.00
RH Turning and Facing Holder for 1/2 in. Square Tool $305.00
LH Turning and Facing Holder for 1/2 in. Square Tool $239.00
Machinable Gang Block $105.00
Shim Kit for Gang Risers $79.00
Recommended items:
ER16M x 3/4 $59.00
Recommended items:
Recommended items:
#1 Turning and Facing Toolholder for Quick Change Post (Size CXA) $75.00
#2 Turning & Boring Toolholder for Quick Change Post (Size CXA) $79.00
#4 Boring Bar Holder for Quick Change Post (Size CXA) $109.00
CXA Boring Bar Holder $89.00
Recommended items:
ER16M x 3/4 $59.00
Recommended items:
Recommended items:
More Info In Stock
CCGT 432 Insert for Aluminum (10-Pk) $109.00
GTN-3 Insert 10-Pack $89.00
16ERAG60 Threading Insert (OD) 10-Pack $185.00
Related items:
Deluxe Turret Tooling Kit (3/4 in.)
Includes everything in the starter kit plus three addtional tools, including LH Turning Tool: SVJBL 12-2C, LH Turning/Facing Tool: SCLCL 12-4B, and ID Threading Tool: CNR0750P16.
More Info In Stock
16IRAG60 Threading Insert (ID) 10-Pack $209.00
Related items:
LH Turning Tool: SVJBL 12-2C $75.00
LH Turning/Facing Tool: SCLCL 12-4B $75.00
ID Threading Tool: CNR0750P16 $75.00
Recommended items:
RH Boring Bar: S12S-SCLCR-4 $76.95
Recommended items:
More Info In Stock
11ERA60 Threading Insert (OD) RH 10-Pack $95.00
Related items:
Deluxe Gang Tooling Kit (1/2 in.)
Includes everything in the starter kit plus three addtional tools, including LH Profile Tool: SVJBL 08-2A, LH Turning/Facing Tool: SCLCL 08-3A and ID Threading Tool: SIR0375H11.
More Info In Stock
11IRA60 Threading Insert 10-Pack $79.00
Related items:
LH Profile Tool: SVJBL 08-2A $46.95
LH Turning/Facing Tool: SCLCL 08-3A $59.00
ID Threading Tool: SIR0375H11 $69.00
Recommended items:
4-Jaw Independent Reversible 6 in. Lathe Chuck (D1 Type Direct Mount) $635.00
Recommended items:
Stop-Loc Setup Tool $22.95
Recommended items:
Z-Axis Travel: 12 (305 mm)
Coolant Tank Size: 10 gallon
Motion
Spindle Power: 3 hp (2.24 kW)
Spindle Speed:
  • Low: 180 to 2,500 RPM
  • High: 250 to 3,500 RPM
Control
Power Required (Primary): Single-Phase, 230 Vac* 50/60Hz, 20A Breaker
Supplied with NEMA L6-20P plug; requires NEMA L6-20R receptacle
Optional Accessories
8-Station turret
Quick-change tool post
Gang tooling system
Automatic 5C collet closer
Features: 80GB program memory
Assembly
Motion
Spindle Speed:
Control
8-Station turret
Gang tooling system
Assembly
