15L Intermediate EDU Bundle
15L Slant-PRO CNC Lathe This product is required for the machine. $20,995.00
<div style="color: red; font-weight: 600;">30% off while supplies last. Discount shown in cart.</div>
15L Printed Manual $25.95
Lifting Kit for Tormach 15L Slant-PRO $429.00
Light Kit for Tormach 15L Slant-PRO This product is required for the machine. $209.00
Automatic Oiler Kit (230V) for 15L / PCNC 1100 This product is required for the machine. $819.00
Touch Screen Kit This product is required for the machine. $589.00
Cord, Power 115 VAC 18AWG 6ft
Floating Tramp Oil Collection Pillow This product is required for the machine. $17.95
4 Inch Length Coolant Nozzle for Turret 10-Pack This product is required for the machine. $48.95
Turret Kit for Tormach 15L Slant-PRO This product is required for the machine. $5,395.00
3-Jaw Reversible 6 in. Lathe Chuck (D1 Type Direct Mount) This product is required for the machine. $635.00
15L/LX Manual 5C Drawtube This product is required for the machine. $275.00
More Info In Stock
GTN-3 Insert 10-Pack $89.00
Related items:
ER16M x 3/4 2  x  $59.00
Huot 5C Collet Rack $55.00
Stop-Loc Setup Tool $22.95
Z-Axis Travel: 12 (305 mm)
Coolant Tank Size: 10 gallon
Motion
Spindle Power: 3 hp (2.24 kW)
Spindle Speed:
  • Low: 180 to 2,500 RPM
  • High: 250 to 3,500 RPM
Control
Power Required (Primary): Single-Phase, 230 Vac* 50/60Hz, 20A Breaker
Supplied with NEMA L6-20P plug; requires NEMA L6-20R receptacle
Optional Accessories
8-Station turret
Quick-change tool post
Gang tooling system
Automatic 5C collet closer
Features: 80GB program memory
Assembly
Motion
Spindle Speed:
Control
8-Station turret
Gang tooling system
Assembly
