15LX CNC Lathe Configurator
15LX Base Lathe $26,949.00
Includes a full enclosure, operator console, air gun, flood coolant system, and washdown kit.
More Info In Stock
15LX Gang Tool Lathe
The base 15LX model comes standard with a full enclosure, operator console, air‑gun kit, flood coolant kit, and washdown kit.
Quick Change Tool Post Kit for 15L/LX Lathe $1,079.00
Additional Options:
15LX Gang Tool Lathe $26,949.00
Long Gang Plate $565.00
15LX Gang Tool Lathe $27,514.00
Includes a full enclosure, operator console, air gun kit, flood coolant system, washdown kit, and <span style="color: #9CAA41;font-weight:600;">long gang tool plate</span>.
More Info In Stock
Long Gang Plate
Additional Options:
15LX Lathe with Turret $29,950.00
Adds an <span style="color: #9CAA41;font-weight:600;">8-station turret</span> and <span style="color: #9CAA41;font-weight:600;">6 in. 3-jaw chuck</span> to the base 15LX.
More Info In Stock
Enhances the base 15LX model with an 8‑station turret and 6 in. 3‑jaw chuck, alongside standard features such as a full enclosure, operator console, air‑gun kit, flood coolant kit, and washdown kit.
Additional Options:
15LX Lathe with Turret & Gang Plate $30,399.00
Adds an 8-station turret, 6 in. 3-jaw chuck, and <span style="color: #9CAA41;font-weight:600;">short gang tool plate</span> to the base 15LX.
More Info In Stock
Short Gang Plate
Waterproof Mouse $31.95
Related items:
4 Inch Length Coolant Nozzle for Turret 10-Pack $48.95
Gang Tool Coolant Accessory Kit, 15L/LX $119.00
Automatic Collet Closer for 15LX $2,845.00
15LX Collet Closer Foot Pedal Kit $195.00
Recommended items:
ER20M x 3/4 in. Collet Chuck $59.00
Recommended items:
ER16M x 3/4 $59.00
Recommended items:
ER11M x 3/4 in. Collet Chuck $44.95
ER11M Collet Nut Wrench $20.95
Recommended items:
Turret Tool Holder Bushing - 1/4 in. ID $69.95
Turret Tool Holder Bushing - 3/8 in. ID $51.95
Turret Tool Holder Bushing - 1/2 in. ID $51.95
Turret Tool Holder Bushing - 5/8 in. ID $46.95
Boring Bar Holder for Turret $349.00
Boring Bar Holder for Turret (Unfinished Bore) $225.00
OD Turning/Facing Holder for Turret $325.00
Short Gang Plate $449.00
3 Position Gang Block $185.00
Gang Block Bushing - 1/4 in. ID $51.95
Gang Block Bushing - 5/16 in. ID $51.95
Gang Block Bushing - 3/8 in. ID $51.95
Gang Block Bushing - 1/2 in. ID $51.95
Gang Block Bushing - 5/8 in. ID $51.95
Recommended items:
1 Position Gang Block $119.00
Recommended items:
RH Heavy Duty Gang Block $195.00
Shim Kit for Heavy Duty Gang Blocks $79.00
Recommended items:
LH Heavy Duty Gang Block $195.00
Recommended items:
Riser for 1/2 in. Center Gang Blocks $215.00
RH Turning and Facing Holder for 1/2 in. Square Tool $305.00
LH Turning and Facing Holder for 1/2 in. Square Tool $239.00
Machinable Gang Block $105.00
Shim Kit for Gang Risers $79.00
Recommended items:
ER16M x 3/4 $59.00
Recommended items:
Recommended items:
#1 Turning and Facing Toolholder for Quick Change Post (Size CXA) $75.00
#2 Turning & Boring Toolholder for Quick Change Post (Size CXA) $79.00
#4 Boring Bar Holder for Quick Change Post (Size CXA) $109.00
CXA Boring Bar Holder $89.00
Recommended items:
ER16M x 3/4 $59.00
Recommended items:
Recommended items:
More Info In Stock
CCGT 432 Insert for Aluminum (10-Pk) $109.00
GTN-3 Insert 10-Pack $89.00
16ERAG60 Threading Insert (OD) 10-Pack $185.00
Related items:
Deluxe Turret Tooling Kit (3/4 in.)
Includes everything in the starter kit plus three addtional tools, including LH Turning Tool: SVJBL 12-2C, LH Turning/Facing Tool: SCLCL 12-4B, and ID Threading Tool: CNR0750P16.
More Info In Stock
16IRAG60 Threading Insert (ID) 10-Pack $209.00
Related items:
LH Turning Tool: SVJBL 12-2C $75.00
LH Turning/Facing Tool: SCLCL 12-4B $75.00
ID Threading Tool: CNR0750P16 $75.00
Recommended items:
RH Boring Bar: S12S-SCLCR-4 $76.95
Recommended items:
More Info In Stock
11ERA60 Threading Insert (OD) RH 10-Pack $95.00
Related items:
Deluxe Gang Tooling Kit (1/2 in.)
Includes everything in the starter kit plus three addtional tools, including LH Profile Tool: SVJBL 08-2A, LH Turning/Facing Tool: SCLCL 08-3A and ID Threading Tool: SIR0375H11.
More Info In Stock
11IRA60 Threading Insert 10-Pack $79.00
Related items:
LH Profile Tool: SVJBL 08-2A $46.95
LH Turning/Facing Tool: SCLCL 08-3A $59.00
ID Threading Tool: SIR0375H11 $69.00
Recommended items:
4-Jaw Independent Reversible 6 in. Lathe Chuck (D1 Type Direct Mount) $635.00
Recommended items:
Recommended items:
Stop-Loc Setup Tool $22.95
15LX LATHE TECHNICAL SPECIFICATIONS
Spindle Power: Continuous: 6 hp (4.5 kW)
- Peak: 10 hp (7.4 kW)
Spindle Speed: Max: 3,500 RPM
Spindle Taper: 5C (With Removable Insert)
Spindle Bore Diameter: 1.53 in. (38.86 mm)
- (With 5C Insert Removed)
Motion
Max Feed Rate:
  • 360 IPM (9.14 m/min)(X)
  • 360 IPM (9.14 m/min)(Z)
EtherCAT Motion System:
  • Closed-Loop
  • True Position
  • High-Performance Servos
Power Required (Primary): 230 Vac Single-Phase*, 30A Breaker
Supplied with NEMA L6-30P plug; requires NEMA L6-30R receptacle
1-Year Warranty against defects in material and workmanship.Extended Warranty available.
Machine Footprint: 54.75 in. × 38.12 in. x 68.25 in.(1390 mm × 968 mm x 1733 mm)
Typical System Weight: Gang Tool Lathe: 1631 lbs. / Turret Lathe: 1764 lbs.
Swing Over Bed: 15 in. (381 mm) Diameter
Swing Over Carriage: 6.2 in. (157.5 mm) Diameter
Z-Axis Travel: 14 in. (356 mm)
Optional Accessories
Full Enclosure (Standard)
PathPilot® Touchscreen Operator Console (Standard)
Air-Gun Kit (Standard)
Washdown Kit (Standard)
8-Station Turret (Optional)
Gang Tooling System (Optional)
Quick Change Tool Post (Optional)
Automatic 5C Collet Closer (Optional)
