15LX Gang Tool CNC Lathe EDU Package
15LX Gang Tool Lathe This product is required for the machine. $26,949.00
The base 15LX model comes standard with a full enclosure, operator console, air‑gun kit, flood coolant kit, and washdown kit.
Long Gang Plate $565.00
Related items:
Lathe Test Piece Kit $10.95
Waterproof Mouse $31.95
Automatic Collet Closer for 15LX $2,845.00
15LX Collet Closer Foot Pedal Kit $195.00
Recommended items:
More Info In Stock
GTN-3 Insert 10-Pack $89.00
Related items:
Recommended items:
ER16M x 3/4 2  x  $59.00
Recommended items:
Huot 5C Collet Rack $55.00
Recommended items:
Stop-Loc Setup Tool $22.95
