24R Basic EDU Bundle
24R CNC Router This product is required for the machine. $17,769.00
24R Printed Manual $25.95
Grease, Hiwin G-05, 400g $59.00
Cable, Ethernet, Cat5e, 10 feet long This product is required for the machine.
IEC320 EXTENSION (IEC320 C13 - IEC320 C14), 2.0M This product is required for the machine.
PathPilot Controller This product is required for the machine. $1,055.00
Standard LCD Monitor This product is required for the machine. $365.00
PathPilot Controller Vesa Mount This product is required for the machine. $25.95
Electronic Tool Setter for 24R This product is required for the machine. $365.00
Amana Tool 24R Starter Cutting Tool Kit $695.00
24R CNC ROUTER TECHNICAL SPECIFICATIONS
X-Axis: 24.75 in. (625 mm)
Y-Axis: 55.75 in. (1415 mm)
Z-Axis: 6.70 in. (170 mm)
Spindle Power: 2 hp / 1.5 kW
Spindle Type: Electrospindle
Minimum Speed: 10,000 RPM
Maximum Speed: 24,000 RPM
Thread Machining: Thread Mill
Power Required
Machine Specs
Linear Motion
Construction
Machine Base: Cast Iron
Gantry: Aluminum
Resolution & Accuracy
PATHPILOT® Controller
80GB program memory
Assembly
24R CNC Router Assembly is available for $2,995.
Power Required
Machine Specs
Linear Motion
Construction
Gantry: Aluminum
80GB program memory
Assembly
Assembly for the 24R is available for $2,995
