24R CNC Router Pro Package
24R CNC Router This product is required for the machine. $17,769.00
Related items:
Leveling Caster Kit, 1000kg $365.00
Grease, Hiwin G-05, 400g $59.00
Cable, Ethernet, Cat5e, 10 feet long
IEC320 EXTENSION (IEC320 C13 - IEC320 C14), 2.0M
1HP Dust Collector with 30 micron bag filter $819.00
Dust Collection Hose, 3 $95.00
Dust Collection Hose, 4 $65.00
Recommended items:
24R Printed Manual $25.95
How to choose system control
24R Router PathPilot Operator Console
24R Router PathPilot Operator Console $2,529.00
$31.95
Waterproof Mouse $31.95
$55.00
Additional Options:
$31.95
$55.00
Standard LCD Monitor $365.00
Touch Screen Kit $589.00
Controller Arm $465.00
Additional Options:
Electronic Tool Setter for 24R $365.00
24R Probing Kit (for use with ATC)
$649.00
Passive Probe, 5 pin DIN connector $649.00
$15.95
ER20 Collet - 10 mm $15.95
$75.00
ISO20 Tool Holder, ER20A, 30mm Gauge Length $75.00
24R Automatic Tool Changer $6,450.00
Storm Vacuum Pump for 24R $3,175.95
Canister Filter for Storm Vacuum System - 3in
Canister Filter for Storm Vacuum System - 3in Canister Filter for Storm Vacuum System - 3in
Storm Vacuum Adapter Kit for 24R - 3in
Storm Vacuum Adapter Kit for 24R - 3in Storm Vacuum Adapter Kit for 24R - 3in
Gasket, 5/16 in. Vacuum Neoprene Foam, 20 Feet
Gasket, 5/16 in. Vacuum Neoprene Foam, 20 Feet Gasket, 5/16 in. Vacuum Neoprene Foam, 20 Feet
Spring-Loaded CNC Drag Knife $175.00
Amana Tool 24R Starter Cutting Tool Kit $695.00
1.5 in. Spoilboard Surfacing Tool $115.00
Huot ER20 Collet Rack $95.00
ER20 Collet - 1/4 in. 4-Pack $43.95
ER20 Collet - 1/2 in. 4-Pack $48.95
ISO20 CNC Operator Set (Inch) $905.00
ISO20 Tool Holder, ER16A, 30mm Gauge Length $75.00
ISO20 Tool Holder Wrench $17.95
Tool Tightening Fixture, ISO20 $129.00
Aspire $1,995.00
More Info In Stock
VCarve Pro $699.00
More Info In Stock
24R CNC ROUTER TECHNICAL SPECIFICATIONS
X-Axis: 24.75 in. (625 mm)
Y-Axis: 55.75 in. (1415 mm)
Z-Axis: 6.70 in. (170 mm)
Spindle Power: 2 hp / 1.5 kW
Spindle Type: Electrospindle
Minimum Speed: 10,000 RPM
Maximum Speed: 24,000 RPM
Thread Machining: Thread Mill
Power Required
Machine Specs
Linear Motion
Construction
Machine Base: Cast Iron
Gantry: Aluminum
Resolution & Accuracy
PATHPILOT® Controller
80GB program memory
Assembly
24R CNC Router Assembly is available for $2,995.
Power Required
Machine Specs
Linear Motion
Construction
Gantry: Aluminum
80GB program memory
Assembly
Assembly for the 24R is available for $2,995
