24VDC Solenoid Kit for 4mm Pneumatic Tubing
$499.00
5 lbs.
2-value 24VDC solenoid kit for 4mm pneumatic tube on backing plate with M12 connector for use with ZA6.
This kit includes two 24VDC solenoid valves with push-to-connect fittings and M12 electrical connectors for plug and play connection to the ZA6 robot outputs and pneumatic gripper accessories. Mounting plate with holes spaced to match threaded PEM fasteners allows you to mount this to the side of the ZA6 electrical cabinet. It is similar to the 51776 24VDC solenoid Kit but includes 4mm push-to-connect fittings (for use with 1/4 in. or 6mm pneumatic tubing) and a push-to-connect cap for one of the outlets. This product will control any pneumatic device that uses 4mm pneumatic tubing but was specifically designed to work with the 39432 Parallel Jaw Gripper product.
Specifications:
  • Type: Two-position valves
  • Input voltage: 24VDC±10%
  • Rated power: 3W per valve
  • Pressure:0.15-0.8MPa
  • Working temperature:-20-70℃
  • Waterproof: IP67
What's in the box:
2 Solenoid valve mounted to backing plate with PTC fittings and M12 electrical connector wiring harness.
