Robot Table
Robust and stable steel table designed to support industrial robots, featuring an extra stiff design for maximum stability, pre-drilled mounting holes for easy installation, and an integrated shelf for the robot's electrical cabinet.
Note: This item has a flat rate shipping fee inside the contiguous United States. This includes shipping to a US port of customer's choice for freight forwarding. Destinations outside of the US will incur additional freight charges.
Key Features:
Sturdy Construction: Crafted from high-quality steel, this table ensures maximum stability and load-bearing capacity.
Extra Stiff Design: The table features an extra stiff structure precisely where the robot mounts. This design element enhances the overall rigidity, minimizing vibrations and ensuring optimal performance during operation.
Pre-Drilled Mounting Holes: To streamline the installation process, the table comes with pre-drilled holes specifically tailored to match the base of the Tormach ZA6 robot.
Integrated Shelf for Electrical Cabinet: The table is equipped with a dedicated shelf located underneath, purposefully designed to accommodate the robot's electrical cabinet. This convenient storage solution keeps the cabinet neatly organized and easily accessible, optimizing the overall workspace.
Durable Finish: The table is coated with a high-quality finish that provides resistance against scratches, corrosion, and other forms of wear and tear.
What's in the Box?
- Table
- Assembly hardware
Leveling Caster Kit PN 39708 sold separately.
