Enclosure Kit, 440M
$2,894.00
124 lbs.
Currently out of stock
Manage chips and coolant with the 440M Enclosure Kit.
Keep chips and coolant where they belong with the 440M’s Enclosure Kit. This durable, powder-coated enclosure features:M/p>
- Clear view, impact-resistant polycarbonate doors provide an unobstructed view for monitoring the machining process
- Durable, 1/4in. (6mm) polycarbonate side windows allow easy access for long parts or maintenance
- Steeply pitched chip trays to funnel chips and coolant back to the Flood Coolant Kit or Dry Chip Collection Kits' chip basket
- LED lighting provides bright, shadow-free illumination from all angles
- Integrated door switch ensures the enclosure is latched shut before machining operations begin
- Dedicated mounting points for the VESA Mount Kit, TTS Tool Rack, web cam, work probe, FRL, Minimum Quantity Lubrication System, and machine oiler accessories.
- Thoughtful cable routing to keep wiring and control cables out of harm's way
Stand and flood coolant kit not included. Some assembly required.
Compatibility: 440M, 440M Stand
Specifications:
| Weight | 124 lb (57 kg) |
| Enclosure Dimensions (L × W × H) |
41.75 in. × 33.5 in. × 32 in. (106 cm × 85.0 cm × 81.0 cm) |
What's in the Box?
- Enclosure shell assembly
- Polycarbonate doors and windows
- LED strip lighting
- Locking door switch
- TTS probe storage bracket
