8L Machine Stand Coolant kit
$509.00
19 lbs.
The 8L Lathe Flood Coolant Kit flushes chips and swarf from the cutting zone
Kit contains the following items:
  • PN 33128 - Coolant Pump
  • PN 37294 - 1 Free Gallon QualiChem XTREME CUT 251C
  • PN 38351 - 90° Push to connect fitting
  • PN 38915 - 38915 - 8 Feet of Coolant Tube
  • PN 31366 - Portable Refractometer - Coolant Tester
Improve cutting performance and surface finishes by keeping your machine’s cutting zone clear with this coolant pump and adjustable coolant manifold. Flood coolant keeps your tools cool and lubricated, keeping them cutting at peak performance longer.
Features:
  • Easily repositionable Loc-Line style nozzle
  • Robust, chip-tolerant coolant pump
  • Drop-in installation
Some assembly required.
  • 8L Lathe
Requirements
    NOTE: This coolant system requires 8L CNC Lathe Stand PN 50520
