770M / 770MX* Stand Bundle
This heavy-duty, welded steel stand provides a rigid foundation for your 770M and 770MX and space to safely store the PathPilot controller. Its centrally-located, rolling chip basket and coolant tank save you time between cleanouts and top-offs, as the chip basket holds up to 50 lb (20 kg) of chips, and the coolant tank holds up to 12 gal (45 L) of coolant. In addition, you can easily:
- Track coolant use with the coolant tank’s fill level gauge
- Refill the coolant tank by sliding it out from the front of the stand
- Level the machine with the stand’s adjustable feet
- Move the stand using common pallet jacks
- Some assembly required.
- 770M
- 770MX* sold before December 1, 2025 with serial number beginning with MF or MH
- PCNC 770 (Series 1 through 3) without an enclosure
- Flood Coolant Kit (1/8 hp) (optional; not included)
What's In the Box?
NOTE: Coolant pump and hoses not included. Purchase of chip tray is also required. This item has a flat rate shipping charge inside the contiguous United States. This includes shipping to a US port of the customer's choice for freight forwarding. Destinations outside of the US will incur additional freight charges.
The stand includes:
- Coolant tank
- Leveling feet
*Not compatible with 770MX mills sold after December 1, 2025 with serial numbers beginning with ML.
