770M Advanced EDU Bundle
770M Mill This product is required for the machine. $11,289.00
770M / 770MX*  Stand This product is required for the machine. $2,885.00
770M Enclosure Kit This product is required for the machine. $3,725.00
770M Chip Tray This product is required for the machine. $509.00
Door Lock Switch Kit This product is required for the machine. $379.00
Lifting Bar Kit $249.00
Automatic Oiler Kit (115V) for 770M / 770MX* This product is required for the machine. $819.00
770M Mill Printed Manual $25.95
770M/M+/MX* PathPilot Operator Console This product is required for the machine. $2,495.00
Flood Coolant Kit (1/8 HP) for 1100M/MX and 770M/MX This product is required for the machine. $639.00
Oil Skimmer Kit for 1100M/1100MX, 770M/770MX, and PCNC 440 This product is required for the machine. $365.00
Power Drawbar Kit for 1100M / 770M This product is required for the machine. $1,515.00
10-Pocket Automatic Tool Changer for the 770M This product is required for the machine. $6,475.00
TTS™ Mini-Shear .750 in. $375.00
Huot ER20 Collet Rack $95.00
Passive Probe, 5 pin DIN connector $649.00
TTS™ Gauge Holder: 10 mm $45.95
770M TECHNICAL SPECIFICATIONS
X-Axis: 14 in.(356 mm)
Y-Axis: 7.5 in.(191 mm)
Z-Axis: 13.25 in.(337 mm)
Maximum Speed: 10,000 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Machine Dimensions
Maximum Feed Rate
Z-Axis: 110 IPM (2.79 m/min)
Assembly
PATHPILOT® Controller
Technical Specifications
Spindle Taper: R8
Maximum Feed Rate
Machine Dimensions
Assembly
