770M Basic EDU Bundle
770M Mill This product is required for the machine. $11,289.00
770M / 770MX*  Stand This product is required for the machine. $2,885.00
770M Enclosure Kit This product is required for the machine. $3,725.00
770M Chip Tray This product is required for the machine. $509.00
Door Lock Switch Kit This product is required for the machine. $379.00
Lifting Bar Kit $249.00
Manual Oil Pump This product is required for the machine. $115.00
770M Mill Printed Manual $25.95
PathPilot Controller This product is required for the machine. $1,055.00
PathPilot Controller Vesa Mount This product is required for the machine. $25.95
Standard LCD Monitor This product is required for the machine. $365.00
770M TECHNICAL SPECIFICATIONS
X-Axis: 14 in.(356 mm)
Y-Axis: 7.5 in.(191 mm)
Z-Axis: 13.25 in.(337 mm)
Maximum Speed: 10,000 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Machine Dimensions
Maximum Feed Rate
Z-Axis: 110 IPM (2.79 m/min)
Assembly
PATHPILOT® Controller
Technical Specifications
Spindle Taper: R8
Maximum Feed Rate
Machine Dimensions
Assembly
