770M Premium Package
770M Mill This product is required for the machine. $11,289.00
770M / 770MX*  Stand $2,885.00
770M Chip Tray $509.00
770M Backsplash Kit $375.00
770M Enclosure Kit $3,725.00
Recommended items:
Related items:
How to choose your oiler
How to choose your oiler?
Oilers
Manual Oil Pump $115.00
Additional Options:
Automatic Oiler Kit (115V) for 770M / 770MX* $819.00
Additional Options:
Lifting Bar Kit $249.00
Door Lock Switch Kit $379.00
770M Mill Printed Manual $25.95
How to choose system control
770M/M+/MX* PathPilot Operator Console
770M/M+/MX* PathPilot Operator Console $2,495.00
$31.95
Waterproof Mouse $31.95
$55.00
Additional Options:
$31.95
$55.00
Touch Screen Kit $589.00
Standard LCD Monitor $365.00
Controller Arm $465.00
Additional Options:
TTS™ Gauge Holder: 10 mm
Related items:
Active Probe Kit $2,169.00
TTS™ Gauge Holder: 12 mm
Related items:
Coolant
Additional Options:
LUBE CUBE Coolant Kit (115 Vac) for 770M / 770MX* $395.00
Coolube 2210, 1 Gallon, w/SDS $119.00
Additional Options:
10-Pocket Automatic Tool Changer for the 770M $6,475.00
microARC 4 Subplate $145.00
Recommended items:
RapidTurn Starter Package
remove
$3,729.00
Additional Options:
RapidTurn Deluxe Package
remove
$4,809.00
Additional Options:
Workholding Setup Guide
Work Stop $65.00
Multi-V 5 in. Jaw Set $155.00
Additional Options:
4 in. CNC Vise $475.00
4 in. Parallel Set $65.00
Work Stop $65.00
Additional Options:
Work Stop $65.00
Additional Options:
SMW Fixture Tooling Plate for 770 Mills
Includes fixture tooling plate (PN 38209) bundled with mounting hardware and the most popular fixturing accessories (PN 52311).
Additional Options:
90° Spot Drill Kit
More Info In Stock
1/8 in. -90° Drills $9.95
1/4 in. -90° Drills $11.95
3/8 in. -90° Drills $15.95
1/2 in. -90° Drills $24.95
Manual Operator Set (Metric) $325.00
TTS™ Saw Arbor: 1 in. $95.00
TTS™ Machinable Blank $38.95
Huot ER16 Collet Rack $95.00
Huot ER20 Collet Rack $95.00
TTS™ SuperFly Cutter Kit
Related items:
TTS™ Mini-Shear .750 in.
Related items:
Mini-Shear - .500 in.
Related items:
Related items:
Related items:
Shear-Hog - 2 in.
ADEH 431 (0.010 $255.00
Related items:
TTS™ Shear-Hog - 0.750 in.
Related items:
Related items:
Related items:
Spindle Speeder $1,895.00
Stop-Loc Setup Tool $22.95
1-2-3 Block Set $42.95
770M TECHNICAL SPECIFICATIONS
X-Axis: 14 in.(356 mm)
Y-Axis: 7.5 in.(191 mm)
Z-Axis: 13.25 in.(337 mm)
Maximum Speed: 10,000 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Machine Dimensions
Maximum Feed Rate
Z-Axis: 110 IPM (2.79 m/min)
Assembly
PATHPILOT® Controller
Technical Specifications
Spindle Taper: R8
Maximum Feed Rate
Machine Dimensions
Assembly
