770MX Equipped Package
770MX - Self-Assembled $24,950.00
Includes 770MX CNC mill, PathPilot operator console, chip pan, stand, and enclosure. This option is self-assembled by the customer.
10-Pocket Automatic Tool Changer for the 770MX (ML Serials) $6,475.00
Lifting Bar Kit $249.00
Additional Options:
770MX - Factory-Assembled $33,950.00
Includes everything in the base machine (mill, operator console, chip pan, stand, and enclosure) plus an automatic oiler, automatic tool changer, and flood coolant system. Ships fully assembled.
Related items:
Waterproof Mouse $31.95
Tool Storage Rack Assembly, 770MX $379.00
Wireless Probe and Tool Setter Kit $6,645.00
Passive Probe, M12 connector $723.95
Pull Stud, BT30 45-Degree
Wired Probe / ETS Adapter Cable $99.00
Required for connection a Passive Probe and/or Electronic Tool Setter. Only 1 cable required per machine.
Recommended items:
Electronic Toolsetter, 24v, M12 Connector $1,685.00
Recommended items:
Haimer 3D Sensor - New Generation (Metric) $623.95
BT30 Tool Holder, Probe, 12mm
Recommended items:
Coolant Options
microARC 4 - 100 mm 4th Axis $4,054.00
4th Axis Driver and Installation Kit (770MX with serial starting ML)
4th Axis Driver and Installation Kit (770MX with serial starting ML) 4th Axis Driver and Installation Kit (770MX with serial starting ML)
microARC 4 Subplate $145.00
Recommended items:
Workholding Setup Guide
Work Stop $65.00
Multi-V 5 in. Jaw Set $155.00
Additional Options:
4 in. CNC Vise $475.00
4 in. Parallel Set $65.00
Work Stop $65.00
Additional Options:
Work Stop $65.00
Additional Options:
SMW Fixture Tooling Plate for 770 Mills
Includes fixture tooling plate (PN 38209) bundled with mounting hardware and the most popular fixturing accessories (PN 52311).
Additional Options:
90° Spot Drill Kit
More Info In Stock
1/8 in. -90° Drills $9.95
1/4 in. -90° Drills $11.95
3/8 in. -90° Drills $15.95
1/2 in. -90° Drills $24.95
Starter BT30 Toolholding Set
ER20 Toolholder 5 Pack
ER16 Toolholder 5 Pack
BT30 Operator's Kit (Metric) $1,575.00
BT30 Tool Holder, End Mill 1/4 in, 50mm
Additional Options:
BT30 Tool Holder, End Mill 3/8 in, 50mm
Additional Options:
BT30 Tool Holder, End Mill 1/2 in, 50mm
Additional Options:
BT30 Tool Holder, Drill Chuck 8mm, 80mm
Additional Options:
BT30 Tool Holder, ER16, 60mm Gage Length
Additional Options:
BT30 Tool Holder, ER16M (Mini-Nut), 60mm Gage Length
Additional Options:
BT30 Tool Holder, ER20, 60mm Gage Length
Additional Options:
BT30 Tool Holder, ER20M (Mini-Nut), 60mm Gage Length
Additional Options:
BT30 Tool Holder, ER32, 60mm Gage Length
Additional Options:
Face Mill 38mm Kit
Face Mill - 38 mm $245.00
Related items:
Face Mill 1 1/2 in. Kit
Face Mill - 1 1/2 in. $345.00
Related items:
Shear-Hog - 2 in. Tooling Bundle
More Info In Stock
Shear-Hog - 2 in. $485.00
ADEH 431 (0.010 $255.00
Related items:
Shearhog 1 in. Tooling Bundle
More Info In Stock
Shear-Hog - 1 in. MIT Cutting Head $279.00
BT30 Tool Holder, Modular, M12, 50mm $95.00
Related items:
DIJET QM Mini Modular Insert High Feed End Mill: 1/2 in. Tooling Bundle
More Info In Stock
DIJET QM Mini Modular Insert High Feed End Mill: 1/2 in. $335.00
BT30 Tool Holder, Modular, M6, 50mm $95.00
Related items:
Stop-Loc Setup Tool $22.95
1-2-3 Block Set $42.95
X-Axis: 14 in. (356 mm)
Y-Axis: 7.5 in. (191 mm)
Z-Axis: 13.25 in. (337 mm)
Spindle Power: 2 hp / 1.49 kW
Peak Spindle Power: 4.5 hp / 3.35 kW
Maximum Speed: 10,000 RPM
Spindle Taper: BT30
Tapping & Threading: Rigid Tapping, Tension/Compression, Thread Mill
Maximum Feed Rate
X- and Y-Axis: 450 IPM (11.4 m/min)
Z-Axis: 420 IPM (10.6 m/min)
Power and Air
Power Required: Single-Phase, 230 VAC*, 20A breaker
Air Required: 90-120 psi
Frame
Table Size: 26 in. × 8 in. (660 mm x 203 mm)
Spindle Centerline to Machine Column: 8.6 in. (218 mm)
Typical System Footprint: 56 in. × 48.5 in. (1422 mm x 1232 mm)
Overall System Height: 88 in. (2235 mm)
Typical System Weight (Factory Assembled): 1500 lbs (681 kg)
EtherCAT Motion System: Absolute Encoder, EtherCAT Servos
Accessories
PathPilot® Touchscreen Operator Console (Standard)
Air Gun Kit
Mist Collector Kit (Must be Wall or Floor Mounted)
WallControl Compatible Tool / Storage Racks
Warrranty
