770MX Advanced EDU Bundle
770MX - Factory-Assembled This product is required for the machine. $33,950.00
Includes everything in the base machine (mill, operator console, chip pan, stand, and enclosure) plus an automatic oiler, automatic tool changer, and flood coolant system. Ships fully assembled.
Related items:
Waterproof Mouse $31.95
Passive Probe, M12 connector $649.00
Wired Probe / ETS Adapter Cable $99.00
Required for connection a Passive Probe and/or Electronic Tool Setter. Only 1 cable required per machine.
BT30 Tool Holder, Probe, 10 mm $65.00
Recommended items:
Electronic Toolsetter, 24v, M12 Connector $1,685.00
X-Axis: 14 in. (356 mm)
Y-Axis: 7.5 in. (191 mm)
Z-Axis: 13.25 in. (337 mm)
Spindle Power: 2 hp / 1.49 kW
Peak Spindle Power: 4.5 hp / 3.35 kW
Maximum Speed: 10,000 RPM
Spindle Taper: BT30
Tapping & Threading: Rigid Tapping, Tension/Compression, Thread Mill
Maximum Feed Rate
X- and Y-Axis: 450 IPM (11.4 m/min)
Z-Axis: 420 IPM (10.6 m/min)
Power and Air
Power Required: Single-Phase, 230 VAC*, 20A breaker
Air Required: 90-120 psi
Frame
Table Size: 26 in. × 8 in. (660 mm x 203 mm)
Spindle Centerline to Machine Column: 8.6 in. (218 mm)
Typical System Footprint: 56 in. × 48.5 in. (1422 mm x 1232 mm)
Overall System Height: 88 in. (2235 mm)
Typical System Weight (Factory Assembled): 1500 lbs (681 kg)
EtherCAT Motion System: Absolute Encoder, EtherCAT Servos
Accessories
PathPilot® Touchscreen Operator Console (Standard)
Air Gun Kit
Mist Collector Kit (Must be Wall or Floor Mounted)
WallControl Compatible Tool / Storage Racks
Warrranty
