8L Advanced EDU Bundle
8L CNC Lathe This product is required for the machine. $11,450.00
8L Lathe Stand This product is required for the machine. $1,869.00
8L Machine Stand Coolant kit This product is required for the machine. $509.00
8L Printed Manual $25.95
8L Lathe PathPilot Operator Console This product is required for the machine. $2,529.00
Deluxe Professional Lathe Tool Kit $185.00
Recommended items:
5C Round Collet Set (35 Pcs.) - Inch $379.00
Interchangeable Point Live Center Set $155.00
Huot 5C Collet Rack $55.00
4 in. Precision 4-Jaw Chuck (5C Mount) $315.00
4 in. Precision 3-Jaw Chuck (5C Mount) $315.00
0XA Tool Holder Kit for 8L $379.00
Stop-Loc Setup Tool $22.95
8L CNC Lathe Extended Warranty $695.00
More Info In Stock
Spindle Power: 1.5 hp (1.11 kW)
Spindle Nose: 5C
Control
Tail Stock
Taper: MT2
Diameter: 0.9 in.(22 mm)
Travel: 2.2 in.(55 mm)
X-Axis: 4.5 in.(114 mm)
Motion
Accessories:
Full Enclosure (Standard)
Automatic Collet Closer (Optional)
Machine Stand (Optional)
Coolant (Optional)
PATHPILOT® Controller
Features:
User-friendly design
Spindle Nose: 5C
Control
Tail Stock
Taper: MT2
Motion
Accessories
Available Accessories:
  • Full Enclosure (Standard)
Features:
  • User-friendly design
