8L Essentials Package
8L CNC Lathe $11,450.00
More Info In Stock
8L CNC Lathe
8L Desktop Coolant Kit $605.00
Additional Options:
8L Lathe Stand $1,869.00
8L CNC Lathe with Stand $13,319.00
More Info In Stock
8L Lathe Stand
8L CNC Lathe
8L Machine Stand Coolant kit $509.00
Additional Options:
Related items:
8L Printed Manual $25.95
How to choose system control
8L Lathe PathPilot Operator Console
8L Lathe PathPilot Operator Console $2,529.00
$55.00
$31.95
Waterproof Mouse $31.95
Additional Options:
3-Prong, Black, 10ft Extension Cord
$55.00
$31.95
Standard LCD Monitor $365.00
Touch Screen Kit $589.00
Controller Arm $465.00
Additional Options:
3-Prong, Black, 10ft Extension Cord $0.00
Deluxe Professional Lathe Tool Kit $185.00
CCMT 2(1.5)1 Insert for Steel (10-Pk) $75.00
CCGT 2(1.5)1 for Aluminum (10-Pk) $85.00
GTN-3 Insert 10-Pack $89.00
Recommended items:
Recommended items:
0XA Tool Holder Kit for 8L $379.00
Recommended items:
Boring Bar Holder (Size 0XA) $32.95
Turning & Facing Tool Holder (Size 0XA) $24.95
Turning & Boring Tool Holder (Size 0XA) $22.95
MT2 Tool Holder (Size 0XA) $36.95
Keyless Drill Chuck - 3/8 in.- JT2 $59.00
MT2 Arbor Adapter for JT2 $6.95
Automatic Collet Closer for 8L Lathe $3,150.00
Recommended items:
5C Round Collet Set (35 Pcs.) - Inch $379.00
Recommended items:
Recommended items:
4 in. Precision 3-Jaw Chuck (5C Mount) $315.00
4 in. Precision 4-Jaw Chuck (5C Mount) $315.00
Interchangeable Point Live Center Set $155.00
Huot 5C Collet Rack $55.00
Recommended items:
Stop-Loc Setup Tool $22.95
Spindle Power: 1.5 hp (1.11 kW)
Spindle Nose: 5C
Control
Tail Stock
Taper: MT2
Diameter: 0.9 in.(22 mm)
Travel: 2.2 in.(55 mm)
X-Axis: 4.5 in.(114 mm)
Motion
Accessories:
Full Enclosure (Standard)
Automatic Collet Closer (Optional)
Machine Stand (Optional)
Coolant (Optional)
PATHPILOT® Controller
Features:
User-friendly design
Spindle Nose: 5C
Control
Tail Stock
Taper: MT2
Motion
Accessories
Available Accessories:
  • Full Enclosure (Standard)
Features:
  • User-friendly design
