All-Angle V-Block / Clamp Set
$59.95
2.2 lbs.
All-Angle V-Block and Clamp set, 1-5/16 in. maximum capacity
All-Angle V-Block with Clamp Set. V-blocks can be used with included clamps to position round bar for inspection and marking. When used with other work holding such as vises or strap clamps these V-blocks can be used to securely hold round bar for milling, drilling, and grinding operations.
- Hardened and Ground Steel Bed
- Included Angle: 90°
- Capacity: 1-5/16 in.
- Length 3-1/2 in.
- Width 1-7/8 in.
- Height 1-7/8 in.
- Tapped Holes: 3
