Aluminum Fixture Plate, 20 in. x 9.5 in. x 10 mm
$81.95
8.5 lbs.
Mill thickness 20 in. x 9.5 in. x 10 mm Aluminum Fixture Plate. Designed to be Machined to suit for low-cost custom fixture design for PCNC 1100.
This fixture plate is made from mill thickness 10 mm aluminum plate.*  Designed as a low cost, disposable option over more expensive Blanchard ground  plates.
  • 20 in. x 9.5 in. , fits working envelope of PCNC 1100 Mill
  • 10 mm thickness(mill finish, not ground)
  • 1/2" locating slots
*This plate is not finish ground and intended to be surfaced on the mill for final flatness.
