Amana Tool 8-Piece Router Bit Set (1/4 in. Shank)
This is a premium 8-piece CNC router bit set designed for general purpose use on wood, plastics, composites, and similar materials. This kit is an excellent starter or upgrade set for educational, prototyping, and hobbyist CNC applications.
Each tool is manufactured by Amana Tool, a leader in CNC cutting technology, and comes packed in a durable Tanos Systainer plastic case for easy storage and transport. The AMS-257 kit is ideal for signmaking, cabinetry, and general CNC routing tasks, and is supported by pre-configured tool libraries in Fusion 360 and Vectric for fast, reliable CAM programming.
Note: This kit is not recommended for aluminum or non-ferrous metal cutting. For aluminum, a dedicated kit is required.
Features
- Versatile: Covers a wide range of CNC routing applications in wood, plastics, and composites
- Professional Quality: Industrial-grade carbide tools for long life and precision
- Ready for Fusion 360: Tool libraries included for quick setup and optimal cutting parameters
- Perfect for Education & Prototyping: Curated for classroom, makerspace, and advanced hobbyist use
What's In The Box?
| Tool Number | Description | Qty |
| RC-45711 | In-Tech Insert Carbide V Groove SHK Single Flute Router Bit, 90 Deg x 11/16 D x 21/64 CH x 1/4 Inch | 1 |
| RC-1148 | Insert V-Groove Router Bit, 60 Deg x 59/64 x 1/4 Inch Shank | 1 |
| 46170-K | Solid Carbide Spektra™ Extreme Tool Life Coated Compression Spiral Router Bit, 1/4 Dia x 7/8 x 1/4 Inch Shank | 1 |
| 46102-K | Solid Carbide Spektra™ Extreme Tool Life Coated Spiral Plunge Router Bit, 1/4 Dia x 3/4 x 1/4 Inch Shank Up-Cut | 1 |
| 46200-K | Solid Carbide Spektra™ Extreme Tool Life Coated Spiral Plunge Router Bit, 1/8 Dia x 1/2 x 1/4 Inch Shank | 1 |
| 46202-K | Solid Carbide Spektra™ Extreme Tool Life Coated Spiral Plunge Router Bit, 1/4 Dia x 3/4 x 1/4 Inch Shank | 1 |
| 46282-K | 2D and 3D Carving Solid Carbide Up-Cut Spiral Spektra™ Extreme Tool Life Coated Router Bit, 5.4 Deg Tapered Angle Ball Tip 1/16 Dia x 1/32 Radius x 1 x 1/4 Shank x 3 Inch Long x 4 Flute | 1 |
| 45771-K | Solid Carbide Signmaking Spektra™ Extreme Tool Life Coated Router Bit, 30 Degree 0.005 Tip Width x 1/4 Inch Shank | 1 |
