Blade Serpent Snakebite Metalworking Blade Coolant
$42.95
8.5 lbs.
Only 2 left
Blade Serpent Snakebite Metalworking Blade Coolant extends blade life and reduces machine wear while improving the cutting finish of all metal applications
Blade Serpent Snakebite Metalworking Blade Coolant extends the life of your blades and increases cutting efficiencies. By reducing the frictional heat created from metal-to-metal contact during production, this superior value sawing coolant reduces machine wear, enables faster cutting speeds, and improves the cutting finish resulting in decreased project time, money-savings, and a better end product.
  • AF50 Autofeed Bandsaw
Specifications
Recommended Dilution
Bandsawing
10:1 to 20:1
Cold Sawing
5:1 to 10:1
Physical and Chemical Properties
Flash Point
None
Appearance
Orange
Hazardous Components
None
pH of 10:1 Dilution
9.5
