California Air Tools 2010ALFC Air Compressor
$395.00
37 lbs.
Only 5 left
California Air Tools 2010ALFC Air Compressor Specifications:
  • 110v / 60 hz @ 7.6A
  • 1.0 HP (Rated/Running) – 2.0 HP (Peak)
  • 2.0 Gallon Aluminum (Rust-Free) Tank
  • 4.00 CFM @ 40 PSI
  • 3.00 CFM @ 90 PSI
  • Ultra Quiet – 60 dB Noise Level
  • Duty Cycle – 70/30
  • Max Pressure: 125 psi
  • Dimensions: L (18.7″) x W (14.2″) x H (14.75″)
  • 1 Year Limited Warranty
  • 4.00 CFM @ 40 PSI
  • 3.00 CFM @ 90 PSI
Features:
  • Oil-Free Pump – Cleaner air for better tool operation.
  • Less maintenance and Costs.
  • Two pressure control gauges
  • One – Female industrial “Push to Connect” quick connector
  • Thermal Overload Protector
  • Condor Pressure Switch
  • Time to fill tank from empty to full – 40 Seconds
  • Recovery time from 90 PSI to 120 PSI – 15 Seconds
  • Maximum continuous running 30-60 min. (Depending PSI & CFM)
  • Aluminum Air Tank – Rust-Free for long life, lightweight only 34.5 pounds
  • Comes Complete with Air Filter
  • Assembled in USA with global components
  • Commercial Use: Refer to State & City Codes
  • The Dual Piston Pump System produces 25% more air compared to other 1.0 Hp air compressor motors.
  • The MP100LF motor/pump is tested for a minimum life of 4000 hours before wear.
