Carbide Insert: SCGT 3(2.5)1 10-Pack
$85.00
0.2 lbs.
The Carbide Insert: SCGT 3(2.5)1 is a positive insert with chipbreaker that is recommended for aluminum machining
Package of 10 SCGT 3(2.5)1 Carbide Turning Inserts. Positive Insert with Chipbreaker. Recommended for Aluminum Machining.
  • Designation: SCGT 3(2.5)1
  • Shape: Square (S)
  • Clearance Angle: 7° (C)
  • Tolerance: Class G (G)
  • Type: Single-Sided (T)
  • Insert I.C.: 3/8 in. (3)
  • Thickness: 0.156 in. (2.5)
  • Corner Radius: 0.016 in. (1)
  • Grade (ISO): N20
  • Coating: Polished
  • Chipbreaker: General Purpose
  • Application: Aluminum
