Carbide Insert: SCGT 431 10-Pack
$65.00
0.3 lbs.
Only 1 left
The Carbide Insert: SCGT 431 is a positive insert with chipbreaker that is recommended for aluminum machining
Package of 10 SCGT 431 Carbide Turning Inserts. Positive Insert with Chipbreaker. Recommended for Aluminum Machining.
- Designation: SCGT 431
- Shape: Square (S)
- Clearance Angle: 7° (C)
- Tolerance: Class G (G)
- Type: Single-Sided (T)
- Insert I.C.: 1/2 in. (4)
- Thickness: 0.1875 in. (3)
- Corner Radius: 0.016 in. (1)
- Grade (ISO): N20
- Coating: Polished
- Chipbreaker: General Purpose
- Application: Aluminum
