Slitting Saw 3 in. x 1 in. x 1/16 in. x 60T
$98.95
0.4 lbs.
The 3 in. x 1 in. x 1/16 in. x 60T is a performance carbide slitting saw with a stagger tooth profile for cutting steel, stainless steel, cast iron and hard materials
Performance Carbide Stagger Tooth Slitting Saw. Fine Tooth Profile is first choice for cutting Steel, Stainless Steel, Cast Iron, and Hard Materials.
  • Material: Micrograin Carbide
  • Diameter: 3 in.
  • Width: 1/16 in.
  • Arbor Size: 1 in.
  • Teeth: 60 (FINE)
  • Tooth Configuration: Stagger
  • Keyway: No
  • Coating: Uncoated
  • Application: Steel, Stainless Steel, Cast Iron, and Hard Materials
