CNMG 322 Insert 10-Pack
$49.95
0.05 lbs.
The CNMG 322 Insert is a negative insert with chipbreaker that is recommended for Steel Finishing
Package of 10 CNMG 322 Carbide Turning Inserts. Negative Inserts with Chipbreaker. Recommended for Steel Finishing.
  • Designation: CNMG 322
  • Shape: 80° Rhombus (C)
  • Clearance Angle: 0° (N)
  • Tolerance: Class M (M)
  • Type: Double-Sided (G)
  • Insert I.C.: 3/8 in. (3)
  • Thickness: 0.125 in. (2)
  • Corner Radius: 0.031 in. (2)
  • Grade (ANSI/ISO): C6/P20
  • Coating: TiN
  • Chipbreaker: Finishing
  • Application: Steel
