CNMG 432 Insert 10-Pack
$145.00
0.5 lbs.
Only 4 left
The CNMG 432 Insert is a negative insert with chipbreaker that is recommended for Steel Finishing
Package of 10 CNMG 432 Carbide Turning Insert. Negative Insert with Chipbreaker. Recommended for Steel Finishing.
- Designation: CNMG 432
- Shape: 80° Rhombus (C)
- Clearance Angle: 0° (N)
- Tolerance: Class M (M)
- Type: Double-Sided (G)
- Insert I.C.:1/2" (4)
- Thickness: 0.1875" (3)
- Corner Radius: 0.031" (2)
- Grade (ANSI/ISO): C6/P20
- Coating: TiN
- Chipbreaker: Finishing
- Application: Steel
