Compact TTS™ Tool Tightening Fixture
$65.00
0.5 lbs.
Only 1 left
The Compact TTS™ Tool Tightening Fixture with a one-way bearing allows you to easily loosen or tighten TTS™ toolholders with one hand
This Compact TTS™ tool tightening fixture uses a one-way bearing for easy one-handed tightening and loosening of TTS™-ER tools or TTS™ Modular Insert tools. Also handy for tightening TTS™ setscrew holders and other TTS tools.
  • No more bruised knuckles! Single handed operation, only one wrench required
  • Insert tool on left side to loosen and right side to tighten with a unique one-way bearing design.
  • Aluminum body with black anodized finish
  • Not to be used with TTS™-ER Tension/Compression Tapping Heads
