Controller Cable - 10 ft.
$44.95
The Controller Cable - 10 ft. is used as an extension or a replacement to connect a computer and Tormach CNC mill
Cable for interfacing controller to your PCNC mill.
  • Compliant with the IEEE 1284 standard.
  • Never use non-compliant cables; improper shielding will result in signal corruption.
  • One 10' cable comes with each PCNC 1100.
  • Only order if you are looking for an extension or a replacement to connect the computer and mill.
