Disc Spring, 40mm OD x 20.4mm ID x 2.0mm thickness
$3.95
0.1 lbs.
Disc Spring, 40mm x 20.4mm x 3.1mm
Drawbar preload springs for 1100MX and 770MX BT30 spindles. 16 disc springs are required for each spindle. Note: If replacing a cracked spring, replace the whole set.
Outer Diameter 40mm
Inner Diameter 20.4mm
Free Height 3.1mm
Material Alloy Steel
Compatible with:
  • 1100MX Spindle
  • 770MX Spindle
