The following items have been discontinued.
Part NumberDescriptionTech DocNote
30303PCNC 1100 lower spindle bearingSB0047The ABEC designation for this bearing is 7008C that can be searched at other vendors
30316PCNC 1100 upper spindle bearingSB0047The ABEC designation for this bearing is 7007C that can be searched at other vendors
301948 in. Motorized Rotary TableN/A38412 is an alternative
302676 in. Motorized Rotary TableN/A38412 is a direct replacement
31101Load meter kitTD1014032096 is functionally equivalent but is not provided with an enclosure. Cutting part of the operator panel is needed for installation of 32096
31320R8 Drawbar for PCNC 1100 Power DrawbarN/A38793 is an equivalent replacement
31750Full Synthetic CoolantN/A37294 can be used as a replacement when diluted per application
318476 in. Tilting Motorized Rotary TableN/A38412 is an alternative
318488 in. Tilting Motorized Rotary TableN/A38412 is an alternative
31875Electronic Tool SetterN/A53379 is a direct replacement
31890Kress 800 Watt High Speed Spindle KitTD31890There is no alternative available
31899 Replacement Probe TipN/A51781 is a direct replaement
32000Stepper DriverN/A53488 is a direct replacement
32789PSG612 grinderUM10159There is no alternative available, support and limited parts are available until Dec 2026
33065X Stepper Motor (SN#10001 - SN#10152 Only)N/A35452 is a retrofit replacement
330896 in. Super Spacer Motorized Rotary TableN/A38412 is an alternative
33146Cast Iron TombstoneD33146There is no alternative available
332161/8 HP Coolant Pump Dual Voltage (115/230V) UpgradeN/A33128 is a direct replacement
332648 in. Super Spacer Motorized Rotary TableN/A38412 is an alternative
33273Generation 1 lathe turretTD1030737335 is a direct replacement
34057ER16 Collet ChuckN/A37101 is a direct replacement
34058ER20 Collet ChuckN/A51666 is a direct replacement
34427Enclosure Kit for PCNC 1100N/AThere is no alternative available
34436Enclosure Lamp, 115VN/AEquivalent available from Amazon
34442Enclosure Kit for PCNC 770N/AThere is no alternative available
34846LED spindle light kitTD10295 There is no replacement
349026 in. Aluminum Soft Top Jaws (2 in. Tall)N/AEquivalent available from US Shop Tools
3492615L tailstockTD10297There is no alternative available
35605PCNC 440 EnclosureN/A51469 is a direct replacement
35671PCNC 440 StandN/A51497 is a direct replacement
35673PCNC 440 Chip PanN/A51499 is a direct replacement
37271CarveSmart 4 in. Master Jaw SetN/AThere is no alternative available
38789EZ-PullerN/A50918 is a direct replacement
394164 in coolant nozzle for turret (pack of 10)N/A35724 is a direct replacement
51091PathPilot Controller - Rev. CN/A51718 is a direct replacement
51681Hypertherm cartridge: SmartSYNC 65AN/AHypertherm part number 428930 is available elsewhere
525081500MX MQL Full KitN/A55207 is a direct replacement
